LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
cmpski's Avatar
Mine is a 2.4 the 250 hp engine is a 2.5. Mine has 11.2 CR the 2.5 11.6 I think. I have a Webcam 993 Super Sport grind. I think the 2.5 is similar to a DC44 grind. Mine ported 993 heads with Ti valves. The 2.5 has Extreme custom heads. The 2.4 has Electromotive Tec-GT ECU. The 2.5 newer Motec.
It appears Electromotive is out of business as is Rasant. Bummer.
1959 Auratium Green 356A Super w/ Rudge wheels
1970 Irish Green 914-6 w/2.2S
Current -1967 Bahama Yellow 912 POLO 2cam4 #1
Handles like a 912 and goes like a 911
www.reSeeWorks.com
Old 01-28-2023, 07:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #501 (permalink)
7.0:1 > 11.3:1 > 7.0:1
Pretty impressive numbers out of those small displacement engines.
Old 01-29-2023, 06:55 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #502 (permalink)
Phoenix's Avatar
I went PMO EFI and couldn't be happier...
Engine Build:
• LN Engineering custom 93mm Mahle Pistons for 9.8:1 compression ratio
• LN Nickie Cylinders
• Existing 70.4 stroke
• DC 40 cam
• Pauter rods
• ARP rod bolts
• Port heads to 35mm Exhaust
• Port heads to 36mm Intake
• Valves ground and lapped
• PMO EFI system
• Clewett EFI management system
• Oil pump: rebuilt by Glenn Yee Motorsports
• 3.2 Carrera front oil cooler with factory brass lines
• High pressure fuel pump
• ARP head studs
• Engine Case machined by Ollie’s
o Time-cert threaded inserts/ case savers
o Shuffle pin case to reduce flex & movement
o Reinforcing weld @ #3 cylinder
o Oil squirters
• Aluminum pressure plate
• ARP flywheel bolts
• Narrowed air deflectors
• Club Sport engine mounts
...Oliver
'73 911T: 2.9ltr w/ PMO EFI
Old 01-29-2023, 02:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #503 (permalink)
Phoenix- Glad to see you are keeping your AC compressor with your ITBs! You seem to be in a well-respected minority!
Old 01-29-2023, 03:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #504 (permalink)
Warmed up 3.0 with TWMs going into my 914 project. Running by spring.
Old 01-29-2023, 03:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #505 (permalink)
Uncertifiable!!!
Uwon's Avatar
Engine Build:
• DC 40 cam
• Pauter rods
• ARP rod bolts
• PMO EFI system
• ARP head studs
o Oil squirters
Looks like a great build.
Can you expand on your starting point? Was it a 2.4?
Can you expand on the EFI used?…….you mention both Clewett EFI and PMO EFI.
TIA
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 01-30-2023, 04:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #506 (permalink)
New-ish 911SC Targa Owner
pampadori's Avatar
Those TWM/Borla throttle boddies and the PMOs are my favorites. They're cast and so they don't have that bling machined look. They also have very stable/static linkage setups. I would love to come across a set.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 01-30-2023, 10:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #507 (permalink)
Random photo dump of my drive by wire ITB turbo setups!
(I make and sell these affordable ITB kits if anyone is interested, just message me)
Old 01-30-2023, 02:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #508 (permalink)
Wow! Super impressive. Beautiful equipment and the performance must be stonking.
At first I thought that was a massive fuel line running across the top of the fan shroud before I realized they were intercooler coolant lines.
Old 01-30-2023, 03:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #509 (permalink)
Full Send Society
I covet that flat fan.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 01-30-2023, 03:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #510 (permalink)
Phoenix's Avatar
TIA
Johan
Hello Johan,
The starting point was indeed a 2.4 with PMO carb induction. This was switched to PMO EFI units using a Clewett engine management set up (computer brain). We were able to keep some of the PMO carb linkage and modify a few bits. This is a much more reliable system also providing the ability to fine tune along the full rev range.
Old 01-30-2023, 05:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #511 (permalink)
Thank you sir!
It's been a long development process that's still going. The performance is absolutely fantastic!
The water to air intercoolers are better than any of the air to air (over the engine) setups by an order of magnitude.
* NO heatsoak at all!
* Normal driving sees intake air temps basically ambient in boost
* Hard driving sees a few degree rise over ambient in boost, after a while.
* Water temp cools back down very quickly.
* Engine cooling fan is completely unobstructed
* Easy to work on anything in the engine bay!
The only way to go.
Old 01-30-2023, 06:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #512 (permalink)
al lkosmal's Avatar
Top Tuning...... absolutely awesome!
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 01-31-2023, 07:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #513 (permalink)
kinda slow
shamrok's Avatar
(I make and sell these affordable ITB kits if anyone is interested, just message me.
Holy crap.
1983 911 SC Coupe
Old 01-31-2023, 11:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #514 (permalink)
Also make NA setups as well of course!
Old 02-01-2023, 11:06 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #515 (permalink)
BoxsterGT's Avatar
Porsche Crest
Top-
Are those some type of Plastic Intake manifolds? Are they printed or cast?
Len
Old 02-15-2023, 11:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #516 (permalink)
how much are they? You can message me if you want, Or I will message you....Thanks
Old 02-15-2023, 03:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #517 (permalink)
Originally Posted by BoxsterGT View Post
Top-
Len
The parts that bolt to the engine are CNC aluminum. Adapters for air filters currently all ABS plastic (works great)
CNC parts for air filter adapters available
Turbo parts are all CNC!
Some pictures of the latest setup:
North Idaho CDA / Spokane area
Instagram: to.performance
MoTeC USA Authorized Dealer
Porsche 959 Department Manager at Canepa *retired after 10 years*
Website / Webstore https://www.topperformancetuning.com/
Old 04-07-2023, 01:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #518 (permalink)
al lkosmal's Avatar
RHD testing
Fire up/test of 3.2SS build with x-faktory/RHD EFI, Megasquirt etc.
regards,
al
RGruppe #669
Old 04-09-2023, 09:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #519 (permalink)
e-ITB setup going on a real 906!
Old 10-21-2023, 01:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #520 (permalink)
