Mine is a 2.4 the 250 hp engine is a 2.5. Mine has 11.2 CR the 2.5 11.6 I think. I have a Webcam 993 Super Sport grind. I think the 2.5 is similar to a DC44 grind. Mine ported 993 heads with Ti valves. The 2.5 has Extreme custom heads. The 2.4 has Electromotive Tec-GT ECU. The 2.5 newer Motec.
It appears Electromotive is out of business as is Rasant. Bummer.
1959 Auratium Green 356A Super w/ Rudge wheels 1970 Irish Green 914-6 w/2.2S Current -1967 Bahama Yellow 912 POLO 2cam4 #1 Handles like a 912 and goes like a 911 www.reSeeWorks.com Last edited by cmpski; 02-02-2023 at 06:18 AM.. |
7.0:1 > 11.3:1 > 7.0:1
Pretty impressive numbers out of those small displacement engines.
I went PMO EFI and couldn't be happier...
Engine Build: LN Engineering custom 93mm Mahle Pistons for 9.8:1 compression ratio LN Nickie Cylinders Existing 70.4 stroke DC 40 cam Pauter rods ARP rod bolts Port heads to 35mm Exhaust Port heads to 36mm Intake Valves ground and lapped PMO EFI system Clewett EFI management system Oil pump: rebuilt by Glenn Yee Motorsports 3.2 Carrera front oil cooler with factory brass lines High pressure fuel pump ARP head studs Engine Case machined by Ollies o Time-cert threaded inserts/ case savers o Shuffle pin case to reduce flex & movement o Reinforcing weld @ #3 cylinder o Oil squirters Aluminum pressure plate ARP flywheel bolts Narrowed air deflectors Club Sport engine mounts
...Oliver '73 911T: 2.9ltr w/ PMO EFI |
Phoenix- Glad to see you are keeping your AC compressor with your ITBs! You seem to be in a well-respected minority!
Warmed up 3.0 with TWMs going into my 914 project. Running by spring.
Uncertifiable!!!
Can you expand on your starting point? Was it a 2.4? Can you expand on the EFI used? .you mention both Clewett EFI and PMO EFI. TIA Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican . Evolution of a Carrera RST, and Sweet Transplant |
New-ish 911SC Targa Owner
Those TWM/Borla throttle boddies and the PMOs are my favorites. They're cast and so they don't have that bling machined look. They also have very stable/static linkage setups. I would love to come across a set.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
Random photo dump of my drive by wire ITB turbo setups!
(I make and sell these affordable ITB kits if anyone is interested, just message me) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Wow! Super impressive. Beautiful equipment and the performance must be stonking.
At first I thought that was a massive fuel line running across the top of the fan shroud before I realized they were intercooler coolant lines. Last edited by rswannabe; 01-30-2023 at 04:12 PM.. |
Full Send Society
I covet that flat fan.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
The starting point was indeed a 2.4 with PMO carb induction. This was switched to PMO EFI units using a Clewett engine management set up (computer brain). We were able to keep some of the PMO carb linkage and modify a few bits. This is a much more reliable system also providing the ability to fine tune along the full rev range. |
It's been a long development process that's still going. The performance is absolutely fantastic! The water to air intercoolers are better than any of the air to air (over the engine) setups by an order of magnitude. * NO heatsoak at all! * Normal driving sees intake air temps basically ambient in boost * Hard driving sees a few degree rise over ambient in boost, after a while. * Water temp cools back down very quickly. * Engine cooling fan is completely unobstructed * Easy to work on anything in the engine bay! The only way to go. |
Top Tuning...... absolutely awesome!
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
kinda slow
Holy crap.
1983 911 SC Coupe |
Also make NA setups as well of course!
![]() ![]() Top- Are those some type of Plastic Intake manifolds? Are they printed or cast? Len ![]() |
CNC parts for air filter adapters available Turbo parts are all CNC! Some pictures of the latest setup: ![]() ![]() ![]() ![]()
North Idaho CDA / Spokane area Instagram: to.performance MoTeC USA Authorized Dealer Porsche 959 Department Manager at Canepa *retired after 10 years* Website / Webstore https://www.topperformancetuning.com/ |
RHD testing
Fire up/test of 3.2SS build with x-faktory/RHD EFI, Megasquirt etc.
regards, al
e-ITB setup going on a real 906!
