Brew Master
Do 911's use more rear brake than front for stopping?
I was checking my rotor temps the other day because I have a humming noise when I slow down or come to a slow rolling stop that I thought might be a brake that was grabbing. My front temps were 116 and my rear were 126 which made me wonder if Porsche used more rear brake than front or if I have a problem I should be looking for.
BTW, I'm thinking wheel bearing installation is on my short list of things I'll be replacing. I think I have the humming sound narrowed down to that. You hear a hum and feel a very slight vibration when it occurs. Thanks in advance for any input. |
pretty sure any vehicle moving forward will use more front brake than rear brake. If your rear brake temp is higher it could be due to less efficient cooling or grabbing or any number of reasons. If your brakes are properly adjusted, they should grab evenly front and back
Make sure parking brake isn't dragging to much.
72 911 Although it is done at the moment, it will never be finished. |
The bias is around 62/38 front the rear on a standard set up
116 - I assume Degrees Fahrenheit isn't very hot and the difference between front and rear is likely to be affected by airflow. At higher temperatures you may see a different result and a hard driven car I would expect rotor temps to be at least 3-400 degF. In the extreme on a hard driven rally car with the right pads discs will glow red hot. Last edited by chris_seven; 08-10-2016 at 04:02 PM.. |
I would also check for sticking caliper pistons as this causes the pads to drag on the rotors and THAT will account for higher rotor temps.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Member 911 Anonymous
What year is your car?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Brew Master
Sorry, I have been out and hadn't been checking this thread. My car is an 85.
For those implying stuck calipers, they would have to be stuck very evenly since both fronts were the exact same temp and both rears were the exact same temp. I think the brakes are likely working as they should. My lines are SS braided. |
Us 3.2's have a proportioning valve in the frunk inline to the the rears. If anything, if that leaks, you will have less braking all around.
![]() You may want to consider rebuilding the caliper seals and check condition of the pistons, if pitted it could be sticking. BTW they are 42MM and NLA in the US. Must get from UK, a member here Chris Seven makes titanium coated ones or SS from Bigg Reds. Very reasonable including shipping. Mine are pitted and not holding pressure well at all, Swapped front pistons, totally changed my braking. 3 out of 4 were pitted and leaking. ![]() Lesson here is changed brake fluid regularly.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 08-14-2016 at 06:07 PM.. |
Things that can cause any rotor to run warmer than usual are frozen pistons, internally swollen lines, different pads, time related heating/cooling curves for different rotor sizes
My rear pads definitely wear out faster if that means anything...
'87 911 Carrera Coupe (go fast, small parts / small kids hauler) '04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius") |
I go through the rears at almost a 2 to 1 ratio on my 87 911 track car. It seems that the Carreras wear our rears faster especially on the track for most people I've talked to
![]() The pad area will have a significant impact on wear rates and you can be certain that any road car has a front brake bias as this will provide much more stability than a rear bias. |
We have been using Pagid Black on the rear for a few years now and they wear and stop just fine. Also, we use Raybestos 43 on the front . . . along with slotted rotors. Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
I'm using pfc08 front and rear. Are you suggesting switching to a different compound for the front and rear?
^^^ if you do not mind the race car squeel.
I thought you might be using stock pads . . . and my thought was that you will need to test some different pads to see what works for you . . . Regards,
? ? ? What squeal . . . the exhaust is 108 dBa . . .
Regards,
Racer
Now I know one reason why you don't run here is Northern California!
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
How do the raybestos compare to PFC? I just bought this set of 08 but I might give those a try as they are priced better next time around |
