What is the "Correct" hose to use for fuel tank venting?
The vent hose on my '74 is old and brittle and I am going to replace tonight. The current hose appears to be clear plastic tubing - is that correct of is it supposed to be vacuum/fuel hose?
Member 911 Anonymous
Oh no, it should be fiber wrap fuel line, check the PAG katalog for the part number.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Clear hose looks correct for the mid year car
Wow, just learned something. Interesting. I guess as long as it holds up to the fuel.
Fleabit peanut monkey
![]() Supplementary data: It rubs the lotion on it's skin or else it gets the hose again. Yes she will, Precious. It will get the hose.
1981 911SC Targa |
Retired, finally
My '77 has fiber wrapped hose, but I've always hated the frayed look so I'm replacing it with smooth surface rubber fuel hose.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project |
You've got the original plastic; same as my 74.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
Registered Minimalist
My midyear had the same clear tube for the vent hose. I tried to move it to install the headlight relay and it burst into a million pieces. I couldn't find the right diameter hose on pelican. I have standard fuel hose from FLAPS that is close but not exact.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Bob// I have seen a lot of funny replies on this forum !!!! but the hose monster is sick@@@ funny@@@@ but sick ///I never would have thought about that quote and scene for a fuel line you must stay up way to late
I used PVC hose from my local hardware store.
The late great Jim Sims says: Quote:
Yep 9mm x 12mm i think is the size. I used 3/8" X 1/2" fuel hose from FLAPS sold by the foot. You will need new hose clamps as the 1/2" OD is too big for the factory clamps.
Also, there's a 'check valve' thingy in the line to the front by the battery. It's a little metal bullet thingy. I'm not sure if it is for smell or keeping fuel going in one direction.
Mighty Meatlocker Turbo
Vern, fess up - you didn't really start this thread to ask something as rudimentary as "what type of vent hose to use" butt wanted to slyly show off yer boss, new fuse & relay panel!
Cars Ruined My Life
Good point, i am tackling that this weekend instead of kicking back. I will post a picture showing my hose when finished Sent from my iPhone using Tapatalk |
oh, did I get a new fuse panel? I completely forgot about that.
You can get the pdf off of Porsches website for your car. Look under Porsche classic.
Chris '75 911s Targa |
Thanks. I guess that's as complete as I'm going to find, eh? I'm going to want to download at leat two, since my car's sort of an amalgem of a 1975 911 and a 1986 turbo.
My 73 had clear hose, I got a kit from sierra madre
I found clear tubing at Orchard Supply Hardware and it was labeled "for chemicals, fuels, and gasses". I bought 5 feet for $2.25 and that gave me enough room to put all the hoses together at the central block and then cut to fit feeding the hose thru the maze of wiring. 1/2 hose diameter seems to be an exact, snug fit.
![]() Installed:
