Identify Brembos.
Could anyone identify the application on these? Thanks in advance
Old 08-17-2016, 05:59 PM
1970 911's Avatar
I agree with soy racer actually. 86 944 turbo brakes
Dean
Old 08-17-2016, 06:15 PM
SoyRacer's Avatar
They look like 1986 944 turbo calipers
1973 Porsche 911 RS
1981 Porsche 931 Euro-Intercooled-GT
1984 Porsche 911 Euro Carrera widebody
1987 Porsche 924s Rallye Spec
Instagram: @soyracer
Old 08-17-2016, 06:16 PM
I agree,944 Turbo. However, there are early and later versions. The early version
have piston seals without the "rubber flap" extending over the piston and the seals are very expensive to replace. The later ones have the more conventional seals with the flap
and are more desireable. Also the later ones have bigger pistons.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 08-17-2016, 06:31 PM
Can these 951 brakes be adapted to a 911sc?
Old 08-17-2016, 06:48 PM
Yes,they can be adapted. They will bolt up to the 3.5" mounting points on your struts if you file/enlarge one of the caliper mount holes. These calipers also need 24mm Carrera brake rotors as your SC has 20mm rotors.
Old 08-17-2016, 07:15 PM
sugarwood's Avatar
Do the 3.2 era cars have Brembo brakes?
Sent from my XT1575 using Tapatalk
1986 Bosch Icon Wipers coupe.
Old 08-17-2016, 07:42 PM
Are the 3.2 calipers a direct bolt on to the sc cars?
Old 08-17-2016, 07:51 PM
Yes, the SC and 3.2 are identical, except the 3.2 Carrera have a wider slot for a 24MM rotor.
Old 08-17-2016, 08:45 PM
Bill Verburg's Avatar
The pictured brakes could be from 944T, 951, 964 they are all the same w/ minor changes are all interchangeable
the fronts want a 26mm min to 28mm nominal to 32mm largest thick rotor, the rears want a 22mm min to 24mm nominal to 28mm largest(w/ some mods) rotor
if you use the fronts w/ a 24mm rotor youare starting at 2mm less than min.
Bill Verburg
Old 08-18-2016, 05:23 AM
FrenchToast's Avatar
If they are from a 944, they look like '87+ because the text is printed rather than raised. Which, if they are a matched set, means they have the larger pistons.
Make sure they are a matched set. They are directional too (the arrows suggest they are at any rate).
Would be interesting to see what shape the piston is. Like uwanna mentions, they changed the shape. I don't know when.
Old 08-18-2016, 05:02 PM
