Originally Posted by uwanna View Post
86-89Carreras use exactly the same system with vacuum servo and module, with two exceptions. They use a 14pin module vs 10 pin, and the module is relocated inside the car under the dash. It operates identically.
Correction: '88-'89 Carreras started using an electrical servo in lieu of the vacuum servo. Basic operation remained the same.
Actually, that's not totally correct. The late CC ECU ('88-'89) is a digital system where the set speed
(a digital count) is stored in a register. The older CC (10 pin) system is an analog system where
the set speed is stored as a voltage on a capacitor. The later system is much more stable, accurate,
and reliable.
Dave
Old 08-29-2016, 08:53 PM
Originally Posted by kyngfish View Post
The way I like to fix the cruise control is, check and see if it's connected. If it is. Disconnect it.
No idea why these cars have cruise control.
You obviously never done a long cross country drive. Try going 900 miles in one day. I have done that several times and cruise is a great thing. Oklahoma City west on I-40 for 900 miles is Flagstaff, AZ. OKC on I-40 east for 900 miles is Maryville, TN. I have done both of those twice.
On the track or the curvy roads it is as useless as the back seats.
Old 08-30-2016, 06:17 AM
Uncertifiable!!!
Uwon's Avatar
+1. I have 379,000 km on my second speedometer. No garage queen! Long distance touring, daily driver, track. The CC has extended my enjoyment of the car.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 08-31-2016, 04:38 AM
