Just replace outer tie rods?
Picked up a used SC rack that already has turbo tie rods on it that seem fine, but the outer tie rods need to be replaced from when then were removed from the car. Any reason not to just replace the very outer ones?
Thanks!
1967 912 (now w/ 50% fewer random holes in it) 911 w/ 3.2 1974 914 (3.2L swap underway) 1984 928s (S4 engine and suspension), 1987 928S4 |
Perfectly fine to replace just the outer tie rod ends. Make sure get the ends for the Turbo Tie Rods as I think there are different from the standard ones.
Kurt |
Thanks Kurt
Vintage Motorsport
I would just replace the outer tie rods.
![]() Here's some stuff I wrote a while back on all of this. Richard Newton |
Surely this is both the tie rod and the track rod end?
We may be getting tripped up on terminology. The picture above is the entire tie rod. I believe the PO is asking if it's OK to replace just the tie rod end, as pictured below. This is certainly acceptable. In my mind, there really isn't an inner and outer tie rod on a 911 per se.
_______________ John 1988 Carrera Targa 3.2 G50 - Sold. 2017 Chevy Silverado K1500. |
I meant OP not PO
And obviously the tie rod end picture I uploaded isn't from a turbo tie rod, but hopefully works as an illustration.
I agree - back to the old chestnut 'two countries separated by a common language' with a few dodgy German translations thrown in to make it a real muddle.
![]() Porsche call the entire assembly a 'tie rod' in the PET and the end joint a 'ball joint'. In the UK the Outer joint is most commonly called Track Rod End and the part that bolts to the rack as a tie rod. I think we use the expression Track Rod End as this is where the tracking (toe) is adjusted. I guess that in the USA the definitions are more commonly shown on the attached sketch.
Retired, finally
I just did this yesterday. Certainly a lot easier than replacing the whole tie rods.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project |
I have these rods ends, never used from my 87. Let me know if your interested?
^^ Those are the proper ones with the castellated nut and pin. There are others with a simple nylock nut which Porsche did not originally use.
Kurt |
PM sent Hanger
Vintage Motorsport
Sorry about the slightly confusing image.
![]() Richard Newton |
