Coloradocurt's Avatar
3.2 Component Question
Recently acquired 85 Carrera Cab and I'm trying to figure out and better understand the function of this component in the front trunk next to the battery. It appears to be a blower to provide airflow to a cooler (AC, oil ???) below the floor pan.
Any input is appreciated, especially comments as to the effectiveness/necessity.
Old 08-30-2016, 03:13 PM
Looks look an aftermarket alarm siren or horn.
Old 08-30-2016, 03:17 PM
Auxiliary fan for front AC condenser
1984 Carrera Targa
Old 08-30-2016, 03:29 PM
dos531's Avatar
Correct. Blows air through the front AC condenser
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
Ducati 748R
Old 08-30-2016, 03:36 PM
It's one of those items that's "unfused" and can cause a fire if it shorts out. There's a fuse available to prevent a problem.
Double check, but I believe this will fit your '85; 1988 Porsche 911 Carrera Coupe - Switches, Motors, Relays, Fuses & Wiring - Page 3
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 08-30-2016, 05:11 PM
fred cook's Avatar
Fuse panel......
The front condenser fan and the evaporator fan are probably pulling power from the same fuse (19 from front of panel). If you have a spare switched fuse (20 was vacant on my car), split the load by moving one lead to the other fuse. Again, on my car, that was the only fuse that pulled nearly 25 amps with the a/c running. Split the load and you should be able to run a 15 amp fuse in each location and keep everything nice and cool. Good luck!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 08-30-2016, 05:40 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Being a CAB and depending where you are located, you can remove all the AC crap and enjoy a lighter car...
Every 10 pounds reduction is like a boost of 1 HP
Who Will Live... Will See
Old 08-30-2016, 05:54 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Plus 4
'85 Carrera Targa
PCA/POC
Old 08-30-2016, 10:37 PM
Barrpete's Avatar
On Carrera's through 1986 that fan has NO fuse whatsoever, and has been known to cause fires. You need either the part jlex referenced or else an inline fuse holder from your local FLAPS for a fix.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 08-31-2016, 07:44 AM
Yea, I would disconnect the wires at the connection until you get the fuse in there.
If your AC works at all, get that fan fused and connected ASAP.
Old 08-31-2016, 07:51 AM
DRACO A5OG's Avatar
Foot well Blowers and Gauge Lights too while you are at it.
'85 Carrera Targa
PCA/POC
Old 08-31-2016, 10:21 AM
Forgetting for a moment the good advice about the fuses, is this blower mainly for hot days being stuck in traffic (top up & AC on) when there's little airflow across the AC condenser?
Old 08-31-2016, 10:53 AM
DRACO A5OG's Avatar
It is always on when ac is turned on
'85 Carrera Targa
PCA/POC
Old 08-31-2016, 11:13 AM
