dmart2rp
The other day I backed my 911SC out of the garage parked it and turned off the engine. After a couple hours I started my 911SC to return it to the garage when I hear grinding noise coming from the cooling fan. Immediately I turned off the engine to investigate, opened the engine compartment lid and turned the cooling fan by hand. I could feel the fan rubbing the fan housing. How could this be? I just installed this brand new Valeo alternator a year ago. Did I have the fan belt to tight? I used five shims between the pulley halves and one behind the washer, this gave me about 5 mm of belt deflection which is recommended by the Bentley repair manual. Is the Bentley repair manual incorrect? Should I have used all six shims between the pulley halves?
Did you actually take the belt off and spin it?
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Possible cracked fan housing. Happens a lot. Try it with the belt a tad looser for now.
dmart2rp
Thanks for the reply John, I noticed a crack in the housing when I replaced the alternator, wasn't a problem at that time. I will remove the alternator and see what I find.
Cars Ruined My Life
worse case, the Valeo unit should have warranty also.
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
shims.
FYI, I used three shims on each side for our M/Y 86. pm me as needed. Best, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
I tend to leave my belt a tad loose because it does tighten up the hotter it gets.
dmart2rp
pete3799,
I should have said I removed the belt. I'm glad this happened at home. |
I have my belt a lot more loose than that. It doesn't seem to slip or flap around.
+1 on what John says!
Check the struts on the alternator shroud for cracks. Your bearings may be OK. ![]() ![]() Replacement aluminum shrouds are available from our host. R&R is an easy project. |
When I took my alternator in to get it rebuilt the guy at the shop said he was having problems getting anything other than chinese bearings, I have had mine in for 2 years now and run my belt just a tad loose and use the Porsche belt, it fits best.
When My bearing went it sounded like I was being followed by a jet plane.
dmart2rp
You are right Gerry, the Woodruff key was not installed correctly by me. I was lucky this happened at home. This could have been a very expensive repair.
