Old 60's Porsche Tech
captainlewis's Avatar
87 Carrera a/c compressor removed questions
I removed my A/C compressor, bracket, and rear condensor. Where is the air flow drawn from, when I use the a/c fan. I am using it because the fresh air flow is so amemic. since I have No a/c now I still drive in 100+ temps. I use the ac fan to keep a lot of air flowing around me through the dash registers, its easy to regulate, better than a furnace blast coming in the window. I keep the windows cracked about an 1"for air. I think the air is just being recirculated bact through the evaporator housing to the registers is this correct? Or is it drawing fresh air in?
1987 911 Cab TRE engine 1952 356A sold ,1960 356B totaled hit by drunk totaled 1979 911 sc Targa sold,1984 911 3.2 Targa sold,1985 911 3.2 Coupe sold 1987 3.2 coupe sold to my son PARTS ENDLESS WORK $$$$$ PREPARING and driving your PORSCHE anywhere with confidence PRICELESS!!
Old 09-06-2016, 03:34 PM
No fresh...all recirculated cabin air
Old 09-06-2016, 05:03 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Thru here and driver side behind foot board:
Yeap, smelly feet, smelly ac
'85 Carrera Targa
PCA/POC
Old 09-06-2016, 06:39 PM
kuehl's Avatar
The AC evaporator blower motor's air is all cabin air recirculating, plus any outside air you allow in. You could 'play' with the fresh box air outlet tubes and branch or "y" them off to the AC vents, it would be fresh as opposed to stale.
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 09-07-2016, 07:20 AM
