How do you tell the regular A caliper from the wide A-caliper?
I know the wide ones take a larger rotor, but is there a "tell" on the wide A caliper in marking or measurement?
1967 912 (now w/ 50% fewer random holes in it)
911 w/ 3.2
1974 914 (3.2L swap underway)
1984 928s (S4 engine and suspension), 1987 928S4
Old 08-28-2016, 07:28 PM
Bland
unclebilly's Avatar
The wide a caliper has a wider spacer between the 2 halves.
Old 08-28-2016, 07:34 PM
Strip in the middle of the halves?
911 w/ 3.2
Old 08-28-2016, 07:41 PM
Bland
unclebilly's Avatar
Yup
Old 08-28-2016, 07:42 PM
OK - got it. Thanks!
911 w/ 3.2
Old 08-28-2016, 07:44 PM
Send a message via Skype™ to Porboynz
Approx 11mm on the wider Carerra caliper
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 08-28-2016, 10:31 PM
seafeye's Avatar
Found a pic of the spacer...
What me speed?
Old 08-29-2016, 02:41 AM
Thanks guys
911 w/ 3.2
Old 08-29-2016, 02:54 AM
Armed Bastard
djb25's Avatar
Wait, don't all the A calipers have a spacer?
Damion
'77 911S Turbo, EFI 2.7l, Carrera intake, Megasquirt 3 with MS3x, Fuel & Ignition
Old 09-07-2016, 03:56 AM
gtc gtc is offline
abides.
gtc's Avatar
Yes, but the spacer in the Wide A (Carrera) calipers is wider.
Wide M rear calipers have a wider spacer and a larger diameter piston than the regular M calipers.
Graham
1984 Carrera Targa
Old 09-07-2016, 07:28 AM
