Question G50 Broken Fork Mount - Input needed
Over Labor Day weekend, my dedicated 911 race car had a failure in the bell-housing. It is a 5 speed G50 with a shortened bell-housing to fit a 1985 911.
One of the cast mounts in the bell-housing failed (photo), so the fork cannot pivot on the throw out bearing. I'm looking for input on repair options. This is a dedicated race car so I'm not committed an OEM solution.
A new bell-housing with machining to shorten costs nearly as much as a used G50 (which would also required machining on the bell-housing). I really don't want to go down that road.
A few thoughts.
  1. Has anyone ever rebuilt a mount in the bell-housing? How did you do this?
  2. FYI - I can't weld the original mount because the broken piece is missing
  3. Has anyone configured another fork/mount solution? For example on the outside of the bell-housing with reinforced mounting points?
  4. Has anyone configured a hydraulic throw out bearing to work with a G50? Room/clearance could be an issue
Thanks in advance for any input. Craig
1985 911 Carrera (IROC RSR Clone); 2001 Lotus Esprit V8; 1967 Chevrolet Camaro SS350; 2009 Kawasaki Super Sherpa; 2013 Moto Guzzi V7 Stone
An understanding wife!
Old 09-09-2016, 11:50 AM
gearhead
California Motorsports.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 09-09-2016, 12:13 PM
This is exactly what I needed to find. Thank you Matt.
Craig
Old 09-09-2016, 12:59 PM
gearhead
You're welcome. They do quality work and a quick turnaround. If you are serious about going hydraulic over a repair, they can do that conversion as well.
1974 914 Bumble Bee
2009 Outback XT
Old 09-09-2016, 01:21 PM
Cory M's Avatar
The G50 in my racecar broke the same way and was fixed by California Motorsports about 8 years ago and it's been fine since.
Old 09-09-2016, 04:44 PM
Great to hear. Thanks for the info.
Craig
Old 09-09-2016, 09:26 PM
Cory, Did you replace both mounts or only the broken one?
Old 09-09-2016, 09:48 PM
Cory M's Avatar
Both mounts were fixed. I think that that is the standard way they do it.
Old 09-10-2016, 08:48 AM
DanielDudley's Avatar
Pardon my ignorance, but what is it exactly that causes this failure, and is it common ?
Old 09-10-2016, 07:16 PM
This is caused by fatigue/stress on the aluminum cast mount. It is unlikely to fail on a street car or occasionally tracked car with OEM clutch components. Add more HP, a high friction disc and high clamp pressure plate.....this can happen.
Old 09-10-2016, 09:31 PM
Diss Member
Quicksilver's Avatar
Another nice detail about California Motorsports is they have more reasonable pricing then a lot of places.
But "Yes", they are the G50 kings.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 09-11-2016, 09:42 AM
