JamesUK
Broken Head Stud.....what now/next?
Maybe this should be in the engine rebuild forum, sorry if I've violated some rule.
So I've just found out I have a broken Head Stud on my 3.2. i'm going to replace the the studs but after that I'm a little lost as to what else I should do. The car is a daily driver and I'm not trying to get 300hp out of her but seeing as the engine is out it would be dumb of me to not do a few things other than the Studs. That's where you lot come in. What should I replace?
I'm going to replace the sound pad. Looks like replacing the fuel lines might be a solid move. I'll have a valve adjustment done but what else should I do.
Please don't suggest a 3.6 swap, 3.4 twin plug or anything crazy like that. I'n not made of money.
As always thanks for your help
Old 09-17-2016, 11:55 AM
Valve grind.
206 637 4071
Old 09-17-2016, 12:07 PM
pete3799's Avatar
How many miles are on the motor now?
Pete
79 911SC RoW
Old 09-17-2016, 12:31 PM
JamesUK
220,000 miles on a 1984.
Old 09-17-2016, 12:38 PM
O'haul?
206 637 4071
Old 09-17-2016, 01:57 PM
DanielDudley's Avatar
What's your hot oil pressure at 3000 RPMs ?
Old 09-17-2016, 02:20 PM
JamesUK
210-230 ish. Why do you ask?
Old 09-17-2016, 05:48 PM
Reiver
Reiver's Avatar
Oil pressure not temp. He's wondering about your bottom end bearings.
At 220 k miles it would be a false economy to just do a top end....I'd do top/bottom rebuild and yes, not inexpensive.
You will probably have more dilivar breaking in the near future.
De Oppresso Liber
Strength and Honor 5th Legion
Old 09-17-2016, 05:52 PM
JamesUK
Yep missed that one! I see 3-4 on the gauge under load
Old 09-17-2016, 06:10 PM
that is not bad oil pressure at 3K RPM. Do a valve job and call it done.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 09-17-2016, 06:41 PM
JamesUK
Yelcab, those are some nice toys you've got there!
I feel that the engine is strong, good pressure, good temps, not losing that much oil no smoke. I was hoping Id have more time before pulling the motor but......here we go.
Old 09-17-2016, 07:03 PM
James, you're going to have the heads, cam carriers, and cylinders off so careful inspection of everything will give you a clue as to the condition of the bottom end. If you pull the rods you can inspect the crank journals and rod bearings without splitting the case, but you can't see the intermediate shaft bearings and those probably need replacing at your mileage. I believe I would go ahead and do the full overhaul.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 09-18-2016, 08:40 AM
RETIRED
Joe Bob's Avatar
Valves and guides....
2012 ML350 3.0 Turbo Diesel
Old 09-18-2016, 10:10 AM
Reiver
Reiver's Avatar
It would depend on the cars history to me.
At 220 k just a top end could be a false economy when everything is out.
OTOH 3.0 bottom ends are known to be good for well over 300K....so, if everything drove properly, temps and oil pressure were strong/positive...ran cool, good psi. ....and I had a solid history of maintenance..like, I knew or had records from day one I might consider just a top end.
That and what you can afford presently....luck with it.
De Oppresso Liber
Old 09-18-2016, 12:39 PM
JamesUK
Thank you all for your inputs. Off down the rabbit hole I go!
Old 09-18-2016, 02:59 PM
Keep us posted what you find on tear down.
Old 09-18-2016, 03:04 PM
