disfrutalaruta
Pulling the Motor - WHAT SHOULD I DO WHILE ITS OUT??
Hey Guys,
My new to me 77 911 S needs a new clutch. My mechanic is gonna pull the motor and install the clutch for me. What should I look at and check on while the motor is pulled? Fuel lines? I am not looking to spend even more money but while its out....
Thanks of any tips
Here is a pic of my project when she was unloaded from the car carrier a few weeks ago:
Shane
Shane
77 911s w/ 3.0L
Architect, Surfer, but mostly a Dad
Old 09-21-2016, 04:03 PM
Shane,
Lots of stuff is much easier with the motor out, of course it all costs money. If I was looking at bang for buck, I would probably replace all the vacuum lines, gaskets and seals on the CIS if you have any doubts about vacuum leaks on the car.
Apparently the large hose that goes to the brake booster is prone to rotting out and is difficult to replace with engine in place, so that might be a good bet to replace.
Rutager West
Old 09-21-2016, 04:26 PM
Dooodahman's Avatar
Here's a list I followed, credit to the original poster, whoever it was....
- Replace CIS vac lines
- check wire ends in engine wire harness and grounds (clean or replace as necessary)
- check for vac leaks (intake runner boots, airbox, etc)
- use Stage8 locking fasteners on the axle when putting back in the car
- classic "triangle of death" oil leaks (thermostat, crankcase breather gasket, oil pressure sensor)
- oil level sender gasket on tank
- oil level sender work?
- fuel injector o-rings and injector sleeves (another vac leak source)
- check the green wire on the dizzy
- new cap, rotor, plug wires if needed
- check for oil leak at the oil cooler (some cars have a weak spot in the case that leaks there. easy fix. Porsche issued a TSB on it.)
- replace oil cooler seals
- adjust valves
- throttle linkage bushings (a lot of people forget this and it will improve throttle response!) get the Weltmeister ones. Pelican sells them.
- Good time to check the dizzy
- check clutch, pressure plate, flywheel, TO bearing, etc.
- good time to replace engine sound pad
- how do your motor/transmission mounts look?
- check the transmission shift shaft seal for leaks
- adjust clutch cable
- rear main seal
- check shift coupler bushings
- clean the engine tin and paint it
- any leaks at the oil return tubes?
- clean the 14-pin connector near the fuse panel
- clean the 14-pin connector that goes to the ECU (on the 14-pin connectors you can use a razor blade to spread the pins so they fit tightly - look at the pins straight on and it will be obvious what I mean)
- check and clean the wires at the starter
- clean or replace the transmission ground strap
Andrew
1987 Carrera Cabriolet
1988 Carrera Coupe (RIP)
Gone are the days we stopped to decide where we should go......we just ride.
Old 09-21-2016, 05:52 PM
subscribed...
Old 09-21-2016, 07:12 PM
- adjust valves
- rear main seal
Great list. Just have the dedication to know when to STOP. Stop before a refurbish of all the suspension and brakes and then......
Old 09-22-2016, 06:20 AM
Buy another 911 to drive while your working on the list.
Old 09-22-2016, 06:47 AM
72911's Avatar
Ha, funny, I just pulled my engine/trans to replace the shift rod seal that was leaking (and helped destroy my shift coupling bushing). So WIWIT I put in a new clutch disk (flywheel and PP was excellent). I replaced the #1 bearing seal (behind the flywheel). I installed new engine/trans mount bushings, removed cleaned and lubed the throw out bearing rod and lever, cleaned, cleaned, cleaned. Replaced the "Trident of Death" "Triple Threat" whatever you call those three seals on the thermostat, breather and pressure sender. I'll add new grease to the CV joints when I get to that point. I re-installed the engine last night and got it secured with the new mounts but stopped there waiting for the grease to show up. Of course that means an oil and filter change also.....whew! not bad for four days....it should be running by tonight.
72 2.7 Driven!
Old 09-22-2016, 07:34 AM
One thing to keep in mind is that removing a 911 engine is a one to four hour job for most relatively handy people, so replacing "tons" of stuff just because it's out isn't necessarily that crucial- take it out next year or later and do more.
Rutager West
Old 09-22-2016, 01:48 PM
grateful user
don gilbert's Avatar
My new thing to do is check the trans main shaft 36mm nut. Prone to work loose, and when it does, good bye 915. Broke my case, carrier, ring gears, and everything else. Nice shifting quiet trans reduced to scrap. Just pull off the cover from the trans and your there. 10 min. job and could save you a ton. Just spent 4200 on a rebuilt one.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 09-22-2016, 02:11 PM
tobluforu's Avatar
Maybe do a search?
Old 09-23-2016, 03:47 AM
Download the PET for your specific car. Review it for every part number from the front seats back and place an order with Pelican. That should cover it. And you'll get a cool Christmas card from them in December.
But in all honesty, Dooodahman's list is pretty comprehensive.
Old 09-23-2016, 05:45 AM
Dooodahman's Avatar
I found the source of the list I reproduced above. it is Tirwin's list. All credit to him.
Andrew
Old 09-23-2016, 07:24 AM
72911's Avatar
What He Said
Originally Posted by rwest View Post
one thing to keep in mind is that removing a 911 engine is a one to four hour job for most relatively handy people, so replacing "tons" of stuff just because it's out isn't necessarily that crucial- take it out next year or later and do more.
^^^^^x2
72 2.7 Driven!
Old 09-23-2016, 10:39 AM
Registered Minimalist
75 911s's Avatar
Shane
You could clean the bajeezus out of it. That's mostly free. :-D
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 09-23-2016, 10:43 AM
Kool-aid-82's Avatar
Never heard this one before... can this be done and resealed without any need of adjustment / shims?
Just new gaskets?
Billy,
MoosgrunMetallic - 81 911 SC - (Carbon fiber Wrap)
Drank the Koolaid in 82
Old 09-23-2016, 11:32 AM
Great Feedback so far....
The only thing I have not seen recommended is to take lots of High Res Pictures.
The first time I took off my CIS, I mixed up two connectors on the backside. What a pain to figure out what I did wrong. Now I mark them (color code) and take pics to make sure they are back on the way they need to be.
After the job is done, the pics and job notes go in a file with the car records.
Best of luck with the Project!!!
Cheers, Louie
SHOPPING CART
Old 09-23-2016, 12:31 PM
disfrutalaruta
This is all great stuff. Thanks for all of your advice. Clutch kit comes in early next week. I hope that I can get some time with my mech while its all apart. Might have to play hookie from work but I want to make sure I get in there to check it all out.
Thanks again - Shane
Shane
77 911s w/ 3.0L
Old 09-23-2016, 05:27 PM
Mrdi's Avatar
Would this list be appropriate for an 88, 911 Carrera as well?
Old 09-24-2016, 02:34 PM
Dooodahman's Avatar
Sort of. Different fuel injection system and transmission.
Old 09-24-2016, 03:13 PM
The Dude abides...
bigel's Avatar
Fuel lines...ask how I know.
'03 Carrera 4S
Old 09-24-2016, 03:17 PM
