81 SC Cold Idle Issue (as in will not idle)
I've been having a cold idle issue for a bit of time. When cold, car starts right up but after a few seconds starts to get rough and dies. Sooo, I did some pressure checking with these results: 1)System pressure - 73 psi. 2)Control pressure - engine cold and running - 54 psi (!) - engine warm and running - 54 psi (?). Ambient temp during testing - 85 degrees. I have the 090 WUR. With engine cold, as I watch psi build, engine runs fine until about 45 psi or so is reached, then it starts to break up. Specs seem to call for about 36-40 psi when cold. Any thoughts? Btw the WUR is a rebuilt unit - swapping that out for the old one made no difference.
Thanks,
Mike
Old 09-25-2016, 11:31 AM
Wur-090.........
Mike,
When the engine is cold, check the resistance (Ohms) of the WUR-090 including your spare WUR. It looks like both WUR's are out of spec. and your cold idle problem is a typical one when the WUR is out of spec. Keep us posted.
Tony
Old 09-25-2016, 12:57 PM
what should the resistance be with a cold wur?
Old 09-25-2016, 02:37 PM
Fleabit peanut monkey
Bob Kontak's Avatar
26 ohms.
1981 911SC Targa
Old 09-25-2016, 02:49 PM
prschmn's Avatar
Wurs came with different heating elements for euro and US spec cars. The US units have a bigger heater and tend to lean the mixture too soon-in the interests of meeting US smog tests.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 09-25-2016, 05:05 PM
theiceman's Avatar
define " too soon" . I have a Us spec engine and it starts and idles flawlessly.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 09-25-2016, 05:36 PM
prschmn's Avatar
If mixture is on the rich side you can bury the misfires. I'm just saying that since the author
didn't specify whether it was/is a US or Euro spec car the different WUR can be a minor problem
Mark
Old 09-25-2016, 05:45 PM
prschmn's Avatar
To elaborate=I used to deal with a lot of Gray Market cars that had the WUR replaced--
and they weren't happy about it. A US spec with lower compression isn't as sensitive.
Mark
Old 09-25-2016, 05:51 PM
that sounds very lean (the idle dieing bit) and the specs on the control pressure are a very lean for cold, but just a little lean for warm! You need to set up the WUR for hot and cold (i.e take apart and adjust), check you airflow sensor plate height, and finally reset your mixture. It could also be other things (air leak, etc) but start with the basics.
In particular, start with the air flow sensor plate height (and check for binding) and then the WUR adjust. When you swapped the WUR over, what pressures did you then have? Also suck on the vac line, and watch the pressures change when in warm control mode.
30 to 87a on the fuel pump relay to hotwire it for the tests, unplug the wur heater to start, then plug it in, no need for the engine running. If you are still getting high control pressures when cold, then disconnect the return line from the WUR and run all disconnected lines into a container. Could be a blockage on the return line somewhere or the WUR itself.
Old 09-26-2016, 01:57 AM
Good morning! My car is the US spec - I have an Oxygen sensor. I measured the resistance this morning on the WUR across the two terminals (I guess that's how you do it) - Cold engine - 9.2 ohms Warm engine (10 minutes running) 9.9 ohms. Outside air temp 78 degrees. Based on these, as well as no change in pressure from cold to warm engine, is my problem my "new" WUR? Thanks for the quick and great feedback!
Mike
Old 09-26-2016, 06:56 AM
T77911S's Avatar
the engine is not warmed up completely.
more noticeable on cold days.
same thing with the AAR. it closes too soon.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-26-2016, 07:41 AM
Wur-090.........
Mike
Mike,
You need a working WUR. You will have this erratic cold idle unless the WUR is fixed and calibrated. I could lend you one for you to use and test. Going back home tomorrow from Sarasota, Fl.
Tony
Old 09-26-2016, 07:45 AM
I contacted the supplier of the WUR that I purchased last year. As it is still under warranty he has agreed to take it back and replace it. It is now on its way to him. I'll keep this thread updated as to the results. Thanks to all for your posts and help
Mike
Old 09-27-2016, 03:01 PM
Bob Kontak's Avatar
Mike
In the interim...........
Find the return fuel line to the tank. Make sure it has no restrictions that could allow fuel to not return freely to the tank.
A partial return restriction can cause your condition.
Originally Posted by strictly View Post
tCould be a blockage on the return line somewhere or the WUR itself.
As mentioned. Don't disregard this.
1981 911SC Targa
Old 09-27-2016, 04:08 PM
Dave Kost's Avatar
You can carefully crack the return line from the WUR to the return back to the fuel tank, if the CCP pressure goes to spec then you have a blockage in the return line. If not then of course its the WUR. (I put the WUR in a bucket and jumped the fuel pump.) Or, you can also run a long fuel line from the return line port of the WUR to a gas can outside of the engine bay.
Glad to hear the rebuild shop stood behind their work.
Good luck and keep us posted. That's how we all learn.
Dave K
Old 09-27-2016, 06:19 PM
WUR warranty........
Mike
Mike,
Good to hear that the WUR is under warranty and a replacement is coming soon. Based from your information, there is no flow restriction in your system and the problem is your out of spec WUR. When you get back the new replacement WUR, check the heater resistance and make sure it has the correct value. Keep us posted. Thanks.
Tony
Old 09-27-2016, 07:11 PM
Replacement WUR update.........
Mike
Mike,
Are you getting a replacement WUR or they will worked on the unit you sent back? Keep us posted. Thanks.
Tony
Old 10-04-2016, 08:30 PM
Hi all. Got the replacement wur yesterday and installed it. Absolutely no change in control pressure from cold to warm (54 psi) or resistance (9.9 ohms cold or warm). I'll check the fuel return line tonight (assuming that Matthew stays east of us). Still wondering if I got another bad wur...
Old 10-05-2016, 02:29 AM
Replacement WUR.........
Mike,
Is this replacement WUR a different unit or it was the same one you sent back to them to fix? Give the rebuilder a call and inform them that 9.9 Ohms is not correct. I would not be surprised if they insist that there is nothing wrong with the WUR. This was the same value you had before. A good WUR-090 should read 25~26 Ohms when the engine is cold.
Request for a good working unit. You will have the same problem/s as before and you are wasting valuable time trying to make the 'out of spec. WUR' perform well. You are not alone. BTW, the return line has nothing to do with your problem (electrical resistance). The return line problem would affect fuel pressure and totally unrelated to resistance (Ohms).
Tony
Old 10-05-2016, 07:25 AM
Thanks Tony. I'll keep all posted as to my progress.
Old 10-06-2016, 04:07 AM
