franklinstower's Avatar
how do I stop this leak at the tensioner?
This is not from the crush washer at the banjo but at the base.
Any ideas?
Thanks,
Paul
'78sc coupe / 89 Westy - EJ25 frankenmotor
Old 11-10-2016, 08:11 AM
Charles Freeborn's Avatar
I have EXACTLY the same leak. Looking forward to an explanation.
Old 11-10-2016, 08:46 AM
I think i found the culprit -
O-Ring that fits on the tensioner should seal the cover.
Look right?
Old 11-10-2016, 09:00 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Ding Ding Ding, Winner Winner Chicken Dinner!
That O-ring shrinks over time and heat cycles. you will need new crush rings for the banjo bolt and fitting besides the new tensioner cover gasket.
'85 Carrera Targa
PCA/POC
Old 11-10-2016, 09:16 AM
I can't believe I missed that when I just had my engine out and put on new chain cover gaskets....remove tin, easily accessible? Muffler drop maybe?
Old 11-10-2016, 09:34 AM
theiceman's Avatar
yeah take the tin off , may need new cover gasket once you remove it.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 11-10-2016, 09:37 AM
DRACO A5OG's Avatar
Get as much off the back for easy access, maybe bumper, muffler. I know PITA but you do not want to struggle doing this, just save yourself from cursing through out the process. Note if you remove muffler, you will need a new muffler gasket. May want to consider partial drop ( 4-6 inches only) without disconnecting anything except coupler
'85 Carrera Targa
PCA/POC
Old 11-10-2016, 09:41 AM
Discseven's Avatar
Originally Posted by franklinstower View Post
Any ideas?
Paul... looking at your pic I'm wondering what sort of crush washers are installed. There's almost a hint of a copper edge. I'm not familiar with '78... but am with '79. This pic shows new crushes installed. Not asserting this is right but am questioning the different appearance between these banjos.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 11-10-2016, 03:05 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Karl, crush washers are typically made of either copper or aluminum and both work. In my experience, they are 100% interchangeable except in situations where very high heat is concerned (like aircraft spark plugs), then copper has to be used.
Old 11-10-2016, 03:22 PM
Porsche used copper and aluminum crush washers. The bottom pic looks like aluminum. Can anyone explain why the two different materials and which should be used where? Seems to me they used aluminum in places where they are supposed to be permanently bolted together, and copper in places where they could be removed and reused, like an oil pan bolt.
Bob B
Wow, Rawknees 'Turbo beat me by three minutes.
Old 11-10-2016, 03:25 PM
When I did the top end the fit of the O rings for that position, that came in the gasket kit, seemed like there wasn't much interference. After some measurements I got a slightly different size with a bit more "squish" in Viton - no drip issues. I don't remember the size. Could be the original ones would have worked - I don't know, I didn't want to take a chance.
Sold: 1989 3.2 coupe, 112k miles
Old 11-10-2016, 05:56 PM
Discseven's Avatar
Am school'd! TY Rono ~~~
Karl ~~~
Old 11-11-2016, 04:23 AM
Karl, I enjoy being your Daddy whenever possible!
Old 11-11-2016, 07:49 AM
Mystery solved for me too. Hoping to do a full drop this winter to freshen up the clutch, so that's on the list too.
Thanks all.
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 11-13-2016, 06:49 PM
Nine9six's Avatar
Not questionng anyones expertise here, but aren't the crush washers supposed to seal the banjo fitting with no leak without the added benefit of the O-ring?
p.s. I'd use alum crush washers in this location. I've typically found alum crush washers a little softer, more malable, and quicker to seal than the coppers.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 11-13-2016, 08:05 PM
911T '72
DeRRis's Avatar
The crush washers seals the banjo. The O-ring seals the casing from the tensioner.
Dennis
Good drivers have dead flies on the side windows. (Walter Röhrl)
Old 11-14-2016, 02:37 AM
Nine9six's Avatar
Ahh, thanks for the clarification, Dennis!
96 993 C2 (Current)
Old 11-14-2016, 09:21 AM
Can we assume the seals that are on the tensioner can be purchased separately?
Is there a specific seal that works better in terms of durability, green, red, viton, etc... Thanks!
Old 11-14-2016, 10:01 AM
That's because "turbo powaaa'", bro!!!
Old 11-14-2016, 10:19 AM
911T '72
DeRRis's Avatar
Timing Chain Tensioner O-Ring 99970169040 - Genuine Porsche - 999-701-690-40 | Pelican Parts
Carrera Pressure-Fed Chain Tensioner O-Ring 99970169040 - Victor Reinz - Porsche - 999-701-690-40 | Pelican Parts
Dennis
Old 11-14-2016, 11:53 AM
