Newbie stupid question
New to 911's and have a stupid question. Does anyone know what this switch does?
Ravi
1974 914 2.0
1975 911s 3.0
2014 Cayenne GTS
2016 Cayman GTS
Old 10-02-2016, 03:07 PM
That Guy
Techno Duck's Avatar
Switches between the driver and passenger door electric mirror.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-02-2016, 03:16 PM
Electric side mirrors.........
Have you tried to adjust your side mirrors? Do you know where the adjuster knob is located?
Tony
Old 10-02-2016, 03:20 PM
No I don't know where the adjuster knob is located.
Ravi
1974 914 2.0
1975 911s 3.0
2014 Cayenne GTS
2016 Cayman GTS
Old 10-02-2016, 03:31 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Drivers side interior door panel upper front. Near the "vent' window.
1981 911SC Targa
Old 10-02-2016, 03:41 PM
Here is what I have on the door panel.
Ravi
1974 914 2.0
1975 911s 3.0
2014 Cayenne GTS
2016 Cayman GTS
Old 10-02-2016, 04:04 PM
kinein's Avatar
Send a message via Yahoo to kinein
Do you have a sunroof
1966 912 with 2.2 911 motor
1986 wide body 911
1995 993 Polar Silver
Old 10-02-2016, 04:20 PM
Bob Kontak's Avatar
Not the same as my 81. Sorry.
Be patient.
1981 911SC Targa
Old 10-02-2016, 04:44 PM
Ravi,
The switch is usually located about where you windwings are. Also, the top part of the door panel does not have the hole for the directional switch. You should pull the top part of the door panel and see if the wiring is there for the switch.
Cesar
Old 10-02-2016, 04:47 PM
Bob Kontak's Avatar
Originally Posted by phatnine11 View Post
Ravi,
Cesar
+1
With a couple of screws you can pull that top panel off and see if the female plug is present.
1981 911SC Targa
Old 10-02-2016, 04:49 PM
Ravi,
Cesar
Another weekend project. Thanks for all the responses.
Ravi
1974 914 2.0
1975 911s 3.0
2014 Cayenne GTS
2016 Cayman GTS
Old 10-02-2016, 04:56 PM
On my SC that's the mirror driver/passenger switch.
Old 10-02-2016, 06:58 PM
If this is on your '75, it was not born with electric mirrors, so it would have not had the switch, either.
You might have a switch that was added by a previous owner. Shine a light inside the trunk towards the switch and see what wiring it is attached to and where the wires go.
JR
Old 10-03-2016, 03:36 AM
wayner's Avatar
Any chance your car has twin plug ignition?
On the factory race cars, while the switch was different, that's where the test switches were located for turning off each ignition box
Probably not that but may be ignition related?
What happens when you move the switch?
SOLD - 914 wide body hot rod
Old 10-03-2016, 03:50 AM
scotricker's Avatar
It's for the sunroof on my 78 SC
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 10-03-2016, 04:21 AM
That's not a sunroof switch, nor is it where a sunroof switch should be. A targa won't likely have a sunroof, anyway...
Not likely to be for twin ignition, either. You'd need two switches for that scenario, not one.
The most common "extra" switches added by owners are for oil cooler fans and kill switches.
JR
Old 10-03-2016, 04:44 AM
Cars and Cappuccino
tdw28210's Avatar
That is the factory sideview mirror L/R adjustment toggle switch. Betting the PO's door top replacement project likely just ignored the mirror adjustment joy stick.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 10-03-2016, 08:45 AM
I have to assume he's talking about his '75 targa.
Electric mirrors were introduced in 1976.
Whatever it is for, it was added after it was built, unless he has a '76 that was first sold in a market where the registration date determined the model year that was recognized.
JR
Old 10-03-2016, 09:36 AM
On my '74 Targa it was added by the PO to manually turn on the fender mounted oil cooler fan.
Tony
1973 914 2.2 FAT Black
1974 911 Targa Lime Green
2018 Macan GTS White
2019 Targa GTS Agate Grey
Old 10-03-2016, 03:34 PM
MBAtarga's Avatar
Could be for aftermarket alarm or fuel pump relay switch for use as theft deterrent - whatever the PO added on the car.
Mark
'83 SC Targa - since 5/5/2001
Old 10-03-2016, 04:17 PM
