| Registered |
				Newbie stupid question
			New to 911's and have a stupid question. Does anyone know what this switch does?
				__________________ Ravi 1974 914 2.0 1975 911s 3.0 2014 Cayenne GTS 2016 Cayman GTS | ||
|  10-02-2016, 03:07 PM |
| That Guy |
			Switches between the driver and passenger door electric mirror.
				__________________ Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 | ||
|  10-02-2016, 03:16 PM |
| Registered |
				Electric side mirrors.........
			Have you tried to adjust your side mirrors? Do you know where the adjuster knob is located? Tony | ||
|  10-02-2016, 03:20 PM |
| Registered |
			No I don't know where the adjuster knob is located.
|  10-02-2016, 03:31 PM |
| Fleabit peanut monkey |
Drivers side interior door panel upper front.  Near the "vent' window.
				__________________ 1981 911SC Targa | ||
|  10-02-2016, 03:41 PM |
| Registered |
			Here is what I have on the door panel.
|  10-02-2016, 04:04 PM |
| Registered |
			Do you have a sunroof
				__________________ 1966 912 with 2.2 911 motor 1986 wide body 911 1995 993 Polar Silver | ||
|  10-02-2016, 04:20 PM |
Not the same as my 81.  Sorry. Be patient.
				__________________ 1981 911SC Targa Last edited by Bob Kontak; 10-02-2016 at 04:47 PM.. | ||
|  10-02-2016, 04:44 PM |
| Registered Join Date: Mar 2005 Location: Rancho Cucamonga
			Ravi, The switch is usually located about where you windwings are. Also, the top part of the door panel does not have the hole for the directional switch. You should pull the top part of the door panel and see if the wiring is there for the switch. Cesar | ||
|  10-02-2016, 04:47 PM |
| Fleabit peanut monkey | Quote:
 With a couple of screws you can pull that top panel off and see if the female plug is present.
|  10-02-2016, 04:49 PM |
| Registered |
Another weekend project. Thanks for all the responses.
|  10-02-2016, 04:56 PM |
| Registered Join Date: Jul 2012 Location: GA
			On my SC that's the mirror driver/passenger switch.
|  10-02-2016, 06:58 PM |
| Registered Join Date: Apr 2005 Location: outta here
			If this is on your '75, it was not born with electric mirrors, so it would have not had the switch, either. You might have a switch that was added by a previous owner. Shine a light inside the trunk towards the switch and see what wiring it is attached to and where the wires go. JR Last edited by javadog; 10-03-2016 at 04:49 AM.. | ||
|  10-03-2016, 03:36 AM |
| Registered Join Date: Apr 2007 Location: I live on the road, I just stay here sometimes...
			Any chance your car has twin plug ignition? On the factory race cars, while the switch was different, that's where the test switches were located for turning off each ignition box Probably not that but may be ignition related? What happens when you move the switch?
				__________________ 73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html | ||
|  10-03-2016, 03:50 AM |
| Registered Join Date: Jun 2009 Location: Santa Fe, NM
			It's for the sunroof on my 78 SC
				__________________ Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." | ||
|  10-03-2016, 04:21 AM |
			That's not a sunroof switch, nor is it where a sunroof switch should be.  A targa won't likely have a sunroof, anyway... Not likely to be for twin ignition, either. You'd need two switches for that scenario, not one. The most common "extra" switches added by owners are for oil cooler fans and kill switches. JR Last edited by javadog; 10-03-2016 at 04:49 AM.. | ||
|  10-03-2016, 04:44 AM |
| Cars and Cappuccino |
			That is the factory sideview mirror L/R adjustment toggle switch.  Betting the PO's door top replacement project likely just ignored the mirror adjustment joy stick.
				__________________ http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) | ||
|  10-03-2016, 08:45 AM |
			I have to assume he's talking about his '75 targa. Electric mirrors were introduced in 1976. Whatever it is for, it was added after it was built, unless he has a '76 that was first sold in a market where the registration date determined the model year that was recognized. JR | ||
|  10-03-2016, 09:36 AM |
| Registered Join Date: Sep 2004 Location: San Jose, Ca
			On my '74 Targa it was added by the PO to manually turn on the fender mounted oil cooler fan.
				__________________ Tony 1973 914 2.2 FAT Black 1974 911 Targa Lime Green 2018 Macan GTS White 2019 Targa GTS Agate Grey | ||
|  10-03-2016, 03:34 PM |
| Registered Join Date: Jul 2001 Location: Lawrenceville GA 30045
			Could be for aftermarket alarm or fuel pump relay switch for use as theft deterrent - whatever the PO added on the car.
				__________________ Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? | ||
|  10-03-2016, 04:17 PM |
