Can someone explain exactly how to disconnect the DME ?
Want to swap in a Steve Wong chip.
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 10-04-2016 at 06:41 PM.. |
There is a retaining clip at the cable end of the connector(right side of your picture)
Push the clip and swing the connector away from the ECU starting at the cable end. There is a hook at the other end of the connector (left side of your picture) that disengages once you swing the connector out. |
Here is a zoom of the right side.
![]() I found this: Quote:
abides.
From the perspective of your photo, press the silver clip to the right to unlatch the connector, then pivot the DME box counter clockwise off of the left side of the connector.
Graham 1984 Carrera Targa |
The silver thing is a spring clip. Push it to the side away from the white nylon connector body and simultaneously pull the connector away from the ECU. You be able to grab it right where the cable goes into the connector body
Thanks guys.
I made the mistake of not wearing my headlamp. When I went back, with LIGHT, it was clear how the clip worked. To get it unclipped and pulled, I got a helper for the 3rd hand. Wong chip is installed ! Here are some more pics, for posterity:
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 10-04-2016 at 06:42 PM.. |
