Southern Class & Sass
Dixie's Avatar
Both windows stopped?
Both my windows stopped working.
I charged the battery. Started the car. Everything works, but the windows won't go up. Odd, because they worked last time I drove it. Fuse is fine. Sunroof works. But none of the switches cause either window to budge.
What do I check?
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 10-05-2016, 11:51 AM
Fleabit peanut monkey
Bob Kontak's Avatar
I am not a 3.2 owner. Just talking here.
On the 3.2's there is a relay that allows the window to close after you turn the key off but only before you open the doors. You may remember doing this? If you do remember, you have the relay. My 81 does not.
I do not know if it can leave you dead in the water (with key on) if it goes kaput. Others do know.
It's a spendy little stinker (pushing $100) with a really fancy German name....just to brighten your spirits.
FENSTERHABER
1981 911SC Targa
Old 10-05-2016, 12:21 PM
Dixie's Avatar
Thanks for the suggestion. There must be a relay, because the windows do work with the ignition off, until the door is opened.
Update:
The driver window started working after five miles. Perhaps there's finally enough voltage to run it? The passenger side is still in-op. On rare occasion, it was balky before. (I'd have to use the passenger switch to "free" it. Then both switches would work.) So further trouble shooting is in order.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 10-05-2016, 03:09 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Check under the seat, the line is connected to the power seats. if disconnected windows will not work either.
'85 Carrera Targa
PCA/POC
Old 10-05-2016, 03:47 PM
Administrator
Dmitry at Pelican Parts's Avatar
What do I check?
Check out this tech article to see if it'll help you further troubleshoot or fix the issue. Best of luck!
Porsche 911 Window Regulator and Motor Replacement | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
-Dmitry
Old 10-05-2016, 03:54 PM
Dixie's Avatar
Switch and all checked out. Cranked the motor by hand a bit, and it started working. Not sure if the brushes stuck, or what, but it seems to be working. Hopefully it will last at least a few years.
Thanks all for your assistance!
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 10-08-2016, 02:17 PM
The passenger window in my '88 is balky at times. Luckily on the '88 model, the crank can open or close the window. When it started messing up, cranking it a wee bit with the provided tool would free it up. After a while, even that wouldn't work. It's working now because I gave it a rap on the motor with the switch engaged (as you would with a balky starter). Probably a weak motor.
You should check your switches and relay to make sure power is actually getting to the motor. If it checks out, then the motor's going bad. The switches can be checked without taking the door panel off. You can't rap the motor directly w/o taking off the door panel, but if you insert the crank tool into the transmission gear, then give the tool a rap while the switch is on, it should be the same as hitting the motor directly. Good luck.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 10-08-2016, 03:57 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Power window relay.
Here you go.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-08-2016, 05:56 PM
After working about 20 or so times, the passenger motor started acting up on my '88 again. I've got it down to a science.... instead of taking off the tweeter cover and messing with the gear, I just gave the door panel a bang with my fist right where the motor is located & that cured it (until the next time). Balky motor for sure, same as a balky starter motor. Trick is, though, you must have the switch engaged at the same time you "persuade" it with a bang. Might be helpful for those whose models don't provide direct access to the transmission gear thru a tweeter cover.
Maybe next year if I get tired of that I'll replace just the motor part & leave the transmission/window regulator alone to save the hassle. Motor appears to be readily accessible and can be separated from the transmission by just two bolts.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 10-11-2016, 07:56 AM
Rescuer of old cars
Arne2's Avatar
Just a small clarification, that feature was not added until the '85 models. My '84 3.2 does not have it.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 10-11-2016, 08:07 AM
Didn't know about it as my '85 didn't have it either. Tried it for the first time yesterday on my '88. It's kind of a neat feature as I always roll the windows down half way while its in the garage to promote good air flow to inhibit mildew.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 10-11-2016, 10:58 AM
Rescuer of old cars
Arne2's Avatar
i do the same on mine, although not half way, don't want to leave a gap big enough to allow a cat to get in.
I had thought this feature started in '85, but apparently it was later than that.
2018 718 Cayman 2.0
Old 10-11-2016, 12:03 PM
