1.2gees's Avatar
Send a message via AIM to 1.2gees
Injector.com (marren injectors) experince?
I've recently sent out 4 injectors to be rebuilt by them, (for my 944 turbo)and I have used this set for a few months, today as I take the intake manifold off, I see carbon build up on cylinder 1&4 which ofcourse leads me to check the injectors, sure enough 1 and 4 are leaking, and #1 is also leaking externally. I've been using these injectors @ stock pressure since the rebuild for about 3 months and less than a week @ 3 bar, which shouldn't make a difference...
I decided to get mine rebuilt @ marren because of all the positive things I heard about them on message boards, I'm going to send them an e-mail and see what they think shortly. Anybody else have anything to share or add?
Ahmet
Cheers!
Old 01-05-2003, 02:53 PM
atlporsche's Avatar
I met Tim Marren at the runoffs once...I was seriously considering him for my CRX injectors...he was a pretty cool guy to talk to .
as for his service?? I'd take them there just becasue word of mouth is so positive.
sjd
Porsche sold, moving back to muscle cars for a bit.
Old 01-05-2003, 04:07 PM
JDaniel's Avatar
I had my injectors serviced there about 2 years ago. Everything has been fine, if not better, since then. No complaints here.
Dan Tolley
1987 911 Coupe
The Owner's Gallery
2006 Audi A4 3.0q Cabriolet
2003 Ford F-150 XL Lumber and Trash Hauler.
Old 01-05-2003, 05:12 PM
Irrationally exuberant
ChrisBennet's Avatar
I had 6 done for my 911 and waited a few months before using them. One was DOA. I was so pissed so I just bought 6 new ones. Since then I have heard of this happening to another person. Don't take this a condemnation of Marren. I believe they worked when Marren sent them back but something happened during storage.
-Chris
Old 01-05-2003, 05:50 PM
1.2gees's Avatar
Thanks for the responses, I will wait to see what they'll say I suppose. I've posted this on a few other boards and the response has been mixed so far. I'm not really going to blame this on them, but may or may not decide to buy larger injectors from them as a result.
Ahmet
Cheers!
Old 01-05-2003, 10:25 PM
jluetjen's Avatar
What's the condition of your fuel filter? As far as the external leaks are concerned - did you replace the o-rings when you replaced the injectors? What's the stock injection pressure for your car (versus the 3 bars that you tweaked it to)?
I've had great experiences with Marren. What I would do is call them up and explain your situation. I'd also ask him to take them back and retest them to confirm the condition. If any are bad, I'd expect him to address the situation.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 01-06-2003, 05:44 AM
Send a message via AIM to elondooberhead
___Posting from buddies house, this is 1.2 gees!___
I have not replaced my fuel filter since the rebuild (as it's been less than 5k miles), the injectors when they were "rebuilt" they came with new o-rings. I wrote them an e-mail last night, and waiting to hear from them as I type this.
PS: The #1 injector is leaking from the injector housing...
Ahmet
87 Flamingo Metallic 951
Old 01-06-2003, 06:54 AM
Here is a post from 1996 on the Porschefans/Rennlist on the subject:
To: porschefans-911@ioio.com, porschefans-914@ioio.com,
Subject: Re: fuel injectors (Warning: LONG)
Anyone who knows me from the old P'Philes days, has seen my postings
on fuel injection issues before. I am a Sr. Design Engineer for a
major automotive fuel injection OEM. I absolutely had to respond to
this thread.
> > From: tmarlow
> > Does anyone know of a specification for how many miles you should put on
> > fuel injectors before replacing them? Are there any tricks to getting
> > them in and out? Aside from the o-rings, are there any other parts that
> > should be replaced while you're doing the job?
> > I've got a 1983 SC with close to 100K miles that sometimes run a little
> > rough when cold. I've got this wild hair that tells me it might be time
> > to replace the injectors. Any concensus on this?
> From: rgrayson@atlanta.com
> There's no hard and fast rule for injector replacement. The typical
> failure mode is clogging or restriction due to debris and fuel
> breakdown. This can happen in as little as 60,000 miles if you use
> cheap gas. If you use good gas, regular use of additives like
> Techron or BG44, and change your fuel filter every 15,000 miles,
Most fuel additives are much better at making the vehicle owner feel
better than for providing any actual benefit. Replacing the fuel
filter every 15-30k is good idea, however. High quality fuel is alo
a good idea.
> they'll last a lot longer. Once they get over 100,000 though, many
> can usually benefit from reconditioning.
What do you do to the injectors specifically? Since they are not
designed for any type of disassembly, short of cutting the welds open,
it's almost impossible for anyone to rebuild an injector. There is
one company that I am aware of that does this, but they have millions
of dollars tied up in specialized equipment, and the rebuilt injectors
that I have tested of theirs, were inconsistent performers, part to
part.
We design our injectors for over a billion cycles of operation. This
would equate to over 300k miles of typical street driving. Mileage
is not really a factor in the demise of an injector. Fuel quality is
far more important.
Debris can be a problem in mechanical systems, like CIS, but the
electronic injectors have a inlet filter that prevents particles
larger than 30-40 microns from entering the valve. Anything smaller
than this can be easily flushed through the valve.
> There's a good article on this subject by Allan Caldwell in the July
> 1996 Panorama.
> Replacement injectors for the SC are relatively inexpensive --
> Imparts has them for $27 each. Bosch injectors for other Pcars can be
> considerably more expensive as in over $100 each.
That's because they are very different animals. CIS injectors are
mechancal orifice tubes, whereas most other Porsche's (non MFI) use
electronic fuel injectors (solenoid valves).
> There aren't any tricks to replacing them, at least on my '85. Not
> sure if an SC is very different...I doubt it. You'll want to disconnect
The 78-83 SC's use CIS injection (see above), which is very different that the
Bosch Motronic system used on the 84-on 911's.
> your battery to avoid fireworks while you're working on the fuel
> lines. Remove various paraphernalia like the air cleaner and blower
> fan to get better access to everything. Remove the A/C compressor and
> pivot it up, leaving the A/C lines connected of course. Relieve the
> fuel pressure by opening the test connection at the end
> of the fuel rail. (Put an absorbent rag under the connector before
> you open it.) Disconnect all the rail plumbing and mounting brackets. Disconn
ect the
> electrical connectors. The rail should then pull out with moderate pressue
> along with the injectors.
Obviously, this is not the procedure for a CIS equipped car, as the
mechanical injection has hard lines running from the distribution
pumpt to each orifice tube.
> When you install the new ones, lubricate the O-rings with automatic
> transmission fluid so they seat properly. Keep everything clean,
Warning: We have tested some of the new Dexron III transmission
fluids and found them to contain compounds which can contaminate O2
sensors. I do not recommend lubricating any fuel system components
with transmission fluid, or any synthetic oils. The best o-ring lube
that we have found is a light mineral oil, or just plain motor oil.
> especially the rail fuel connectors or else you'll have leaks. After
> you button everything back up, run the engine and check closely for
> any possible leaks. Shut it off and check again. Fuel leaks are bad
> things and can really ruin your day.
I can second that!
> By the way, in September I plan to open my shop -- INJECTOR CLINIC --
> and will offer injector cleaning services with discounts to list
> members. I'm getting the ASNU cleaning machine shown on page 44 of that same
> Pano. I'll post a note when I open my doors.
> Hope this helps.
> Richard Grayson, rgrayson@atlanta.com
> INJECTOR CLINIC - Fuel Injector Service & Repair
> '85 Porsche 911, '73 Datsun 240Z (slow restoration)
> PCA member, IZCC#309
Warning #2: We have tested some of these "injector cleaning
systems". We have found that on certain types of injectors,
specifically the older pintle types typically found on Porsche's,
these systems can have some very limited benefit, and a whole lot of
drawbacks. Newer injector designs, especially non-pintle designs,
derive no known benefit from "injector cleaning", but still suffer
from the drawbacks.
Here's the bottom line:
Pintle type injector clogging is due to varnish build up on the
orifice edges, and thepintle O.D., at the end of the injector. As
this varnish builds up, the effective metering orifce diameter is
reduced. The results in a drop in flow rate, and a deterioration of
proper spray pattern.
The varnish is a resultant of two factors, the presence of very long
chain hydrocarbons (called olefins) in your fuel, coupled with heat.
When you shut off your engine, there is a residue of fuel that remains
on the tips of the injectors. As your engine heat soaks, the oelifins
in this residue get converted, by the surplus heat, to varnish. Here
is an analogy. Margarine contains a very high percentage of olefins.
If you put some in a pan, and heat it on your stove, what forms on the
bottom of your pan? Right, Varnish. Is that burnt of crud easy to
remove? Not without some serious elbow grease or a really nasty
solvent.
Here's the dilemma: In order to effectively remove this
crud from the ends of the injectors, you need to "scrub" the orifice
metering area clean. Mechanical contact with this part of the
injector will damage it, dramatically altering the flow rate. Most
solvents won't remove this crud from the end of the injectors in any
reasonable amount of time. Acetone can take days to dissolve a few
microns of the stuff. The only solvents that we have found to remove
this varnish are so aggressive, they typically cause other problems
with the injectors They attack the rubber and plastic materials
commonly used in the manufacture of electronic fuel injectors. They
are also extremely harmful to humans.
We have seen some field returns from our customers that have been
internally damaged by some of these witches brew solvents used in
"Injector Cleaning". We had one case of a fuel leak, caused by an
o-ring that had disintegrated due to some "cleaning" solution. This
fuel leak resulted in an engine bay fire, which resulted in a very
unhappy vehicle owner. We contacted the vehicle owner directly, and
found that he had just had his injectors cleaned about a week
previously, at a local garage. We supplied him with all of the
evidence of the damage done, and he filed suit against the garage, and
against the manufacturer of the cleaning system. He won a nice
settlement.
Mr. Grayson, if you choose to enter into a fuel injection cleaning
business, please be sure to get some very good liability insurance.
Here's my advice: The next time that the pimply
faced kid at Jiffy Lube suggests that the injectors in your wife's
Honda need "cleaning", Just politely say no thanks and keep that $50
in your pocket. It will probably save you another visit to your
mechanic, and it might even save your life.
Cheers,
Tony Staples
tstaples@piedmont.net
'88 Carrera Cabrio
'87 944S Track Car
"Nothing like a little horsepower to brighten your day!"
Old 01-06-2003, 07:03 AM
I don't have any specific exp with this place, but here is an email from the Rennlist about a place that was recommended for injector work.
> >what do they do except run some techtron through them? Seems new
> >would be better or running your own techtron. Unless you have a
> >problem why fool with something..shop around, i know the prices on
> >the Carrera injectors have comedown in the last few years. Bruce
> >Abbott
> No, RC Engineering blueprints the injectors.
> They first measure the flow rate and evaluate the spray pattern. Then
> they clean the injectors until they flow all the same. Finally, all
> new O-rings, gaskets, etc. are replaced with new pieces. When they are
> returned, they are indistinguishable from new.
> For example, 1990 Mazda RX-7 w/ lopey idle, stumbling acceleration.
> 70,000 miles.
> I had tried various fuel injector cleaners, as additives, including
> the Redline Oil products in various concentrations without noting any
> improvement.
> Injectors sent in. One injector simply dripped. The other had spray
> patterns ranging from "poor" to "fair". Afterwards, spray patterns
> were all "good", and the flow rates were within <0.3%. Idle was fine
> after that, and acceleration smoothed out considerably. Cost was $125
> for 4 injectors, including next day shipping. Cost for 1 new injector
> for this car is $250.
Old 01-06-2003, 08:56 AM
1.2gees's Avatar
Thanks for the extra info gentlemen. I have e-mailed marren yesterday, still have not heard back. I will try calling wednesday if I'm not contacted by then, but I think I pretty much just made up my mind about marren as I do research about injector rebuilding I pretty much see that there's only so much that can be done, and I paid good money for mine!
Ahmet
Cheers!
Old 01-06-2003, 11:06 PM
