Lsd
What is the best way to find out if a transmission is LSD.
Transmission is not mounted in the car.
Old 10-11-2016, 04:52 PM
bgyglfr's Avatar
I believe you turn one of the output flanges the other should turn the same direction. If the other turns opposite, it's not an lsd.
70T 2.7RS spec.
68L coupe
Old 10-11-2016, 06:40 PM
Or take off the side plate and look inside...
Remove flange bolt, remove flange, remove side plate, carefully hammer it off, examine differential.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 10-12-2016, 07:39 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1, Just raise and spin the wheels
'85 Carrera Targa
PCA/POC
Old 10-12-2016, 07:43 AM
also a factory LSD trans will have a 12 in the middle of the serial number if its a 915
Old 10-12-2016, 07:53 AM
Peter Zimmermann's Avatar
Yep, with BOTH rear wheels OFF the floor, trans in neutral, and e-brake off, turn the right rear wheel. If the left rear wheel turns the same direction, you have LSD.
Keep the Shiny Side UP!
Pete Z.
Old 10-12-2016, 07:58 AM
Bill Verburg's Avatar
th spin the wheel test doesn't always work
one reason is the lsd is worn out and another is that the low pre-load used on some just doesn't act the way you would expect
The ZF 40% unit in my '76 works as described above, you can also feel it in tight turns at low speeds
The much more effective Porsche Motorsports 40/65 in my 993 is never felt at all under normal low speed operation but is far more effective at track speeds and loads, it can appear to be open w/ the casual casual wheel spin test.
one way to improve the test is to hold one wheel will spinning the other, this places a bit more load and the lsd resistance can usually be felt
for oe lsd look for the 12, this is a 915/73 from an '86 911 seril # 03454
Bill Verburg
Old 10-12-2016, 12:52 PM
It would help if the OP posted the type of car he's got...
Pete Z.
Old 10-12-2016, 04:43 PM
As I mentioned motor and transmission are not mounted in the car . Motor is a 3.2 L
I spined the flange and they went opposite direction .
The vin number is not fully readable . I don't think it is an LSD.
Thanks to all who educated me on this topic .
Old 10-12-2016, 04:52 PM
