Occasional User
Tunnel Carpet install question
I am installing Appbiz RS carpet in my G50 car - I am deleting center console. Can I unscrew the 3 bolts that hold shifter in place and tuck carpet underneath? Or am I going to screw something up. Should I just glue carpet as close as possible to bracket/frame? I am also thinking about tucking a shift boot under there, too. Opinions welcomed. Cheers
Vince 2015 Boxster S, Black & Black 1989 Carrera Silver Coupe, Silk Grey - sold 2009 Cayman S White, Full Cocoa - sold 1972 911E Silver Coupe, Pepita & Black - sold |
I think you can unscrew that. On a 915 you definitely can. Someone who's done it on a G50 should weigh in though.
Jason - Austin, TX 82 911 SC targa (gone, but not forgotten) 92 968 coupe |
Recreational User
Use the rubber shift boot, and let it sit on top of the carpet. No need to tuck it under. I did that on my car and the boot stays put. The edges of the carpet are hidden under it, so there is no need to make the hole perfect.
I deleted the center console on my 915 gearbox car and added an AppBiz carpet as described by proschenut. If you use a 915 rubber boot, there is a groove around the bottom that you can shape the carpet opening to so that it fits flush to the boot. When installed, it should cover everything up nicely. |
Occasional User
OK - Thanks to all for insight / advice - I will not mess with it. Much appreciated
