When do you replace your transmission fluid?
Yeah, when do you replace your transmission fluid? number of miles or months/years?
Thanks.
Fat butt 911, 1987 |
Reiver
Often drive spiritedly in 100 degrees plus and no radiator on my '83 915 tranny. In cooler climes prob not as much an issue.
De Oppresso Liber Strength and Honor 5th Legion |
Member 911 Anonymous
Per Bentley 15K miles or 2 years.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
At the beginning of every track season (spring). I put maybe 1500 miles on it per year. Oil's cheap, as the saying goes...
88 Carrera, Guards Red
if you have never done it, it is time.
I've gotten cars with over 100k miles on the original gearbox fluid, and there were zero issues.
Change it, but it's not anything to freak out over. I'd be more worried if it were very low.
1986 Bosch Icon Wipers coupe. |
I'll probably change mine next year, when I think it it will have had about ~12k miles on it, but I've had Redline synthetic oil in my SE-R's gearbox for at least 60,000 miles and I don't have to even think about it.
'80 SC Targa Avondale, Chicago, IL |
umm, I think I'll do it sometime soon...
Waynes book (Project #36) says every 30,000 miles or 2 years assuming 15k/year. He also says depends on how you drive the car, track vs. Street. I put about 2k on mine per year street only so maybe in 10 years i will change it again. I used Mobil 1 gl-5 synthetic on mine, costs about 10/quart, shifts like buttah now. 89 with G50. Does your trans have lim slip diff? If so get oil with additive.
Frank 1989 911 Carrera Targa 3.2L, all stock 78k miles (as of Dec 2023) "The Machine" |
15k miles? That's 5 or 10 years for me :lol:
Guys,
I drive around 1k to 3k miles a year. Saying 3k is probably a little too exaggerated. I usually change it when I like, some times once per year, some times after 2 or 3 years. Engine oil too, I used to change it 3 times a year. Then I reduced to twice a year. Friends told me that I was wasting oil/fluid, then now I do it once a year. I guess once every 2 or 3 years for transmission fluid is ok huh. Thanks guys.
Fat butt 911, 1987 Last edited by rnln; 10-20-2016 at 12:30 AM.. |
Reiver at what level does your oil temp gauge goes up to? 210?240 farenheit?i use mine as a daly driver (82 SC) and the needle goes up to the last withe mark but never more,thanks for the advise
IMO, it depends on what transmission and what lube you are running. With a G50 running synthetic gear lube, you can extend the intervals longer than an earlier car with non-synthetic lube. The Porsche type synchronizers in the 901 and 915 transmissions don't like the slippery synthetic lube, so you have to accept shorter drain intervals with the non-synthetic lube. I have read that the big problem is the action of the differential gears on the oil molecules. The gears sort of chop up the oil molecules after long use. Apparently,synthetic oil withstands this better. So, looking through the records on my 1986 with a 915 that I acquired this year, it looks to be about 15k since the last gear oil change. Time for me to do another one.
1990 964 Coupe 1986 Carrera 3.2 Targa |
I do my 915 oil change every other year. I do drive my car and I have put over 6,000 miles on it this year.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
gearhead
I change my gear oil every 2-3 years on my street cars. 15k mi on the ones driven a lot. Track cars are a totally different beast.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
The best bet is to change it when you want to get away from the nagging wife. This might be daily, or it might be every 10 years. Either way seems to work
gearhead
So since you are going 100k between changes can we assume she left you?
They are many options:
1) she left 2) she died 3) she never nags and does whatever I say 4) I'm a swinging bachelor 5) I'm gay 6) I'm a swinging gay bachelor 7) ???
Caveman Hammer Mechanic
My trans starts to shift not so nicely, as with new fluid. I use Swepco 201 and when fresh it shifts like a Swiss piece of machinery, old like a cheap Italian car. The shearing of the oil molecules by the gears causes it to breakdown, add some localized heat and the fluid gives up the ghost.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
+1, 915 synchros need help to slow down, synthetic will not allow that. Plus if you have LSD, it growl like a TANK, ask me how I know.
