87 Carerra, 3.2 liter en
Help Checking CHT Sensor
I have my Bentley and I thought I knew what I was doing but after reading some past posts I may be al screwed up in trying to check my CHT sensor. Here is what i did
1. Made sure car off b/c measuring OHMs
2. Located White sensor amongst 3 sensors in engine bay.
3. When I pulled the sensor apart I have the two pronged CHT sensor. Temp outside was 59 Fahrenheit. Was not sure whether to measure the male or female side of the sensor so I did both. When I measured the female side (wire harness to car) the reading was 1.068.
3. When i measured the male sensor wire self I got 3.002.
What is confusing me is when I read this past post by one of the forum members: "Check your head temp sensor. It's the gang of three electrical connectors on the upper left of your engine, the white connector. When cold it should be around 2500-3500 ohms, when hot around 200-300 ohms."
This is where things stand. First did I do the readings correct. Second does the reading show a good or bad CHT?
Another forum member wrote in another post: "check the wire from the CHT to the DME." Is this what i did by my above testing or is this another test and if so, how?
Thanks everyone
Old 10-23-2016, 11:04 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Change the resolution on your DVM to get a better reading.
You connect both connectors with each probe for the DVM
Member was asking you to confirm if it is single or updated doubled wire
'85 Carrera Targa
PCA/POC
Old 10-23-2016, 12:11 PM
Draco:
I was certain I had the meter set for an OHM reading and not a voltage reading
Old 10-23-2016, 12:14 PM
DanielDudley's Avatar
When you get a 3.002 on your meter, you should look for a K somewhere on the display, meaning 3K or 3002 ohms. The K will be somewhere on the display, but not always in a way that you will clearly recognize it as a kilo symbol for 1000.
The male connector end is the sensor. Sounds like your sensor is good. Or should be.
Old 10-23-2016, 12:37 PM
DRACO A5OG's Avatar
Originally Posted by Srwilliams View Post
Draco:
As Brother Daniel stated above you should have several settings for OHMS to be read out aka "resolution" but 3.002 probably means 3002K. So verify with Bentley but but it sounds like your CHTS is shot.
'85 Carrera Targa
PCA/POC
Old 10-23-2016, 01:51 PM
OK Fellas:
Am supposed to measuring the female side or the male side. I thought the measure was for the female side (nonsensor side). On that side I measured again and got 1.067.
If I am supposed to measuring the sensor male prongs please let me know
Old 10-23-2016, 03:08 PM
DRACO A5OG's Avatar
"male" side aka sensor side only.
'85 Carrera Targa
PCA/POC
Old 10-23-2016, 03:24 PM
thanks so much Draco.
I was measuring the wrong side when I went back and did my retest. Tomorrow I will retest the male side. But I am pretty certain the reading I got was 3.002. So to you does that mean the sensor is no good if that is the correct reading?
Old 10-23-2016, 03:43 PM
Detached Member
Hugh R's Avatar
Measure cold and hot, mine checked out fine cold, but stayed at the 2,500 range when hot and it thought it was still cold and dumping rich fuel in which would stall out the engine after warming up. Fairly easy to change it out, the hardest part was getting the new rubber grommets back in the holes in the body. Took about an hour start to finish.
Hugh
Old 10-23-2016, 03:58 PM
DRACO A5OG's Avatar
Post OHMs when COLD & when Hot.
'85 Carrera Targa
PCA/POC
Old 10-23-2016, 05:41 PM
