Wer bremst verliert
JohnJL's Avatar
Making a carbon fiber airbox - input appreciated
Hi all,
As I test fit the engine in the latest Gretchen I began measuring and planning for the air filter assembly. This car has an aluminum Carrera intake, and from a rough placement in the engine compartment I have about 6" clearance from the throttlebody to the firewall.
I had used a giant oval-cone K&N filter with one of their 90 degree elbows on this motor in another car in the past and it would fit this car too but 1. it looks ghetto (my diagonal cut to fit the throttle body wasnt clean, 2. it is a heavy mother and 3. it indiscriminately takes air in from throughout the engine bay.
So in the spirit of competely skunkworking this thing, I came up with a plan...my priorities were to address those 3 things above. I have done enough fiberglass work to know I dont have the skills to turn out a piece that would be acceptable to me. So I concocted an approach to use some pre-fabbed carbonfiber pieces and plates to make something.
I drew up plans for and order some pieces. Sorry, I am travelling now and dont have the drawings with me but it is basically a 90 degree 3.5" elbow from the throttlebody to an airbox located over the 4-5-6 cylinder bank mounted on the stock intake bolts. The elbow enters the airbox on the driver's side. The box will measure 5.5" tall x 12" wide by 12" deep. The box has 5 closed sides and its open end facing the rear of the car. A rectangular filter will fit into the open end supported by a 1" CF flange around the perimeter made from the 90* CF angle. Then a lid also with a CF angle flange sandwiches the filter in place, and forms a mouth aimed at a 45* angle right into the decklid grill. I know, a picture is much more helpful...
Here is my list of materials:
90* elbow from carrera throttlebody to airbox:
CF Elbow
CF plate forming the box and filter mouth:
solid CF prepreg plate 1/16"
CF 90* angle reinforcement for corners and filter flanges:
CF angles for corners and flanges
Filter:
Rectangular K&N filter
I havent worked with CF before. I found this video helpful in building confidence...lets see if that is misguided...
https://www.youtube.com/watch?v=EWzN6GZeEzs&t=35s
Easy Composites Video
I have a bunch of Hysol products on hand for the actual bonding. Initial research incdicated the e120 was the go?
I am interested in input from others about the approach, methods, tips and tricks...
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 11-21-2016, 08:59 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hi John - sounds like an awesome project. If you end up documenting it in detail, check out this link as you may be interested in becoming one of our DIY Project Experts.
I've also found the below link to give you some ideas/troubleshoot the install that you're going to be doing. Hope it helps and best of luck!
C2/C4 Airbox Modification / Upgrade
-Dmitry
Old 11-21-2016, 12:02 PM
I would like to have a MFI style airbox set up for my Jenvey ITB's. The Jenveys have straight manifolds, and the spacing between each TB is bigger than the MFI/Weber/PMO type set ups. I was thinking of buying an original MFI airbox, cut and space it out to make it fit, and then make molds out of FG. And then make new ones in CF or FG... Have anyone tried this?
1985 928 S3, 5-speed
1987 Carrera, current project
2012 Jaguar XF 5.0, Wife's d.d.
2009 Boxster,sold, 2000 Boxster, sold, 1995 993, sold, 2004 Maserati, sold, 2000 996, sold, 1971 914, my college car, 1966 911, sold way too cheep, Lots of VW's...
Old 11-21-2016, 03:14 PM
Wer bremst verliert
JohnJL's Avatar
Originally Posted by Dmitry at Pelican Parts View Post
Hi Dmitry,
Thanks, I did that to a 993 I owned years ago.
Old 11-21-2016, 05:00 PM
This was a project of mine. i started off building boats at an early age.
Old 11-21-2016, 05:48 PM
Wer bremst verliert
JohnJL's Avatar
That is so cool. You have skills I will never have. Great job!
Old 11-21-2016, 06:06 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Originally Posted by JohnJL View Post
That is so cool. . . . Great job!
Agreed - absolutely love it!
Old 11-21-2016, 06:13 PM
Administrator
+1 looks absolutely incredible.
-Dmitry
Old 11-22-2016, 12:17 PM
Wer bremst verliert
JohnJL's Avatar
What size is that filter? K&N site calculates needing 65 sq in in filter area, yours looks smaller than that? The one I selected above is also slightly smaller, I may return for a Miata filter which is 6.5x12. Same sq in as used in a new AMG C63 so I cant imagine it would choke a 250hp 3.0.
Old 11-23-2016, 04:05 AM
Kudos for the CF effect/build. However, inlet air temps are pretty much ambient in the engine compartment at speed. Use a paper filter. It's cheaper..... and better.
Sherwood
Old 11-23-2016, 10:22 AM
K&N makes more promises than president campaign speech
Old 11-23-2016, 10:17 PM
Wer bremst verliert
JohnJL's Avatar
Yeah, but I see you used one too! What size is it?
The filter will be partially visible with the trunk open, at least the K&N looks OK and does a decent enough job filtering. The paper ones look like crap as they yellow/grey almost immediately.
Old 11-24-2016, 01:55 AM
robust filter sized to fit my project
Old 11-24-2016, 09:08 AM
GaryR's Avatar
Send a message via ICQ to GaryR
After seeing what passes through a K&N filter I would NEVER use one on my car... Stock paper element works just fine.
Gary R.
Old 11-24-2016, 09:23 AM
Lo0ks like you have lots of other work on car. why not something like this
AireTEK Fresh Air Induction Kit-HighFlow, 911, 1984-89
Porsche 911 (1974-1989) - Intake System - Page 2
Old 11-24-2016, 09:25 AM
Welcome to Rothsport Racing - Engine Products
K&N
Old 11-24-2016, 09:28 AM
Wer bremst verliert
JohnJL's Avatar
The first one doesnt look like it will clear the firewall with an alu intake and stock throttlebody. Second not sure either will fit the 90mm tb? Both still leave a bit of a .... how do I say this...not the aesthetic I am hoping for.
Old 11-24-2016, 10:49 AM
Wer bremst verliert
JohnJL's Avatar
Thats for the later 964 intake I believe. The twin-chamber like yours. Mine is the simple 86-88 single-chamber alu intake.
Old 11-24-2016, 10:52 AM
I've been using them for 30 years on every machine I own (bikes, cars, diesel truck, race and public roads) and have never had a problem with dirt getting past them.
Old 11-24-2016, 12:56 PM
Would you mind sharing how you made the manifold?
Did you make a female mold or a core to lay up the carbon?
How did you manage the seams, lap joints?
Thanks,
Looking forward to your feedback.
Old 11-25-2016, 11:18 PM
