Rob G.
sterring wheel issue
I have a 1983 911sc cabriolet. Haven't used it for a while, and when I drove it recently I noticed that the steering wheel column has about 1/2 play up and down.
I have never noticed this before, hoping someone could shed some light on this issue, and provide some guidance on my next step. do I need to take it to a mechanic, or is this something I can attempt to repair on my own?
thank you in advance.
Rob G.
Old 12-21-2016, 12:11 PM
Probably the steering wheel column nylon bush that has collapsed, my 79 SC just had the same issue. Easy fix, you need to buy the improved metal bush from pelican parts, think its about $15, easy to fit. Remove wheel, take off the clip, clean out as much of the broken original bush then gently knock in the new one, there is a pelican how to do it thread I think, once you have the bush you should be up and running again in about 15 mins if you have a few basic tools.
Just an FYI, I carried on driving mine for a week like it was once I confirmed the issue and understood it, so if yo uconfirm the issue is the same you can decide if you want to drive it, I dont think anything can go anywhere, it just feels a little bit strange
Old 12-21-2016, 12:28 PM
Rob G.
Thanks for the reply, I found the article and will order the parts.
Looks like a repair I can handle.
Old 12-21-2016, 01:25 PM
Don't go for the metal bushing use this one
Steering Column Support Bushing (Nylon material), 911/911 Turbo (1974-89)
Part #: PEL-ML-STR
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 12-21-2016, 01:36 PM
RETIRED
Joe Bob's Avatar
I replaced the bushing in MY 83 cab, very easy and it was perfect afterwards.
2012 ML350 3.0 Turbo Diesel
Old 12-21-2016, 03:53 PM
petercory
Does the column or the steering wheel have 1/2" of play; if it's the column, the mounting bolts are probably loose, simply remove the Tach to tighten them. If the play is in the steering wheel then and only then do you need to replace the bushing.
Old 12-21-2016, 06:07 PM
RETIRED
Joe Bob's Avatar
The original steering wheel bushing is plastic. If it hasn't gone yet, it will.
Old 12-21-2016, 06:45 PM
Part #: PEL-ML-STR
Yes, that's the famous Mitch Leland steering bushing. Simple to install but a quite elegant fix. Install it and your problems are over for as long as you own your car.
Do a search on Mitch Leland and you will find numerous threads with "how to" tricks and info.
EDIT: here's the thread
Mitch Leland's Steering Wheel Bushing
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 12-21-2016, 08:29 PM
Rob G.
Replying to Peter Corey,
It feels like the entire column can move up or down 1/2 inch; how do I remove the tach to check on the bolts?
Thanks again
Old 12-22-2016, 09:48 AM
Rob G.
I just wanted to say thank you to everyone who contributed to this post. I purchased the Leland bushing and with ipad in hand, read the instructions and removed the old bushing (it was in tiny pieces surrounding the steering column) and installed the new bushing. What a difference.
My next step is dealing with the oil leaks but that is for another post.
Rob
Old 01-09-2017, 04:01 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Congrats
'85 Carrera Targa
PCA/POC
Old 01-09-2017, 04:14 PM
petercory
To remove the Tach, I'd recommend removing the Steering Wheel first, then see if you can grasp the rubber gasket under the black bezel and slowly pry the tack out with your fingertips (rock it from side to side). If you don't have any lick that way, start with either the Fuel or Oil Press gauge and reach behind the tach and push it out. The 2 bolts in question are below the Tach; tighten them and reverse the procedure.
I got the same bad advise about the bushing and ordered one only to find out that the column was the problem; anyone want to buy a brand new (unused) Mitch Leyland Bushing for $20, please PM me.
Old 01-09-2017, 06:58 PM
