Registered Minimalist
Broken throttle body ball stud. How do I fix?
I was a bit heavy handed while trying to pop the ball socket off the ball stud on the throttle body lever. The result is not pretty:
![]() It seems I can't buy just the arm. I found a full TB on eBay for $150, but wow, that's one expensive mistake. I'm not sure I'm willing to pony up that much unless I give fixing it the old college try. Pelican sells the replacement ball socket, and I was thinking I could drill out the stud on the arm and put in a new ball stud. Got some questions for the hive mind. Are the ball studs 8mm? Where can I get one asap? Where can I look for a replacement arm if replacing the ball stud wont work? Or am I stuck buying an entire Throttle Body? Does anyone have an old TB they can sell me the arm/linkage off of? What is the preferred method for popping these off? I did fine on the others, but this one of course snapped. Thank you in advance for the help.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Member 911 Anonymous
Ouch.
You want to pull straight out so the inner spring can compress and allow the ball to slip out. However, if rusted or filled with debris it makes it almost impossible to pull off. As far as the fix, do you have access to a welder?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
or Maybe you can grind the remaining stud off and tap a hole and use something like this:
I might have one give me a day or two to find one and I'll pm you.
That would be amazing if you do! Thank you sir!
Grind both sides flush and punch out the remains. Rob a ball from your stash of throttle bellcranks, grind the swage off and punch it out. Squeeze the ball into the lever in a vise and put a small weld on it. Probably need another socket piece too.
this
Drill it out and replace with one of these.................8mm ball stud
![]() regards. al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
PM me your address.......
I have a box full of assorted CIS throttle bodies that I will never be able to use in my life time. Take care of the shipping cost and will send you a complete lever with the ball joint. Happy holidays.
Tony |
Tony I'll take you up on that.
Al, Dpmulvan, John and Draco - Thank you all!
Break a Leg Brother!
No! No more breaking stuff! :-D
I just need to slow down. Getting antsy because I haven't driven in a few months - A Bit nervous about getting it to run after changing up so much in the CIS. It's a good thing this online community is so helpful. Grateful for the collective knowledge here.
When that socket won't come off the ball, you can just unscrew the rod from the socket.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
i have a TB off of a 2.7s. $25
better yet, get a 3.0 TB and put on there, it has a bigger TB. I put one on my 77s. that's why I have the 2.7 TB.
I would love to see a "Definitive CIS performance Upgrade Thread" I would start it, but I know nothing. I've heard discussion of ROW Fuel distributors, larger intake runners (you must have larger ports in the head - slippery slope) and now a larger TB from the 3.0 onto the 2.7. I would love to hear Al, John and Tony's thoughts on this - though I think they would say, don't bother, save up for PMOs! ![]() Interesting that a $150 upgrade (3.0 TB) might give a bit of a performance boost on the breathless stock 2.7.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads Last edited by 75 911s; 11-29-2016 at 11:05 AM.. |
Last minute call........
Duane, Found a couple of '75 throttle bodies in my junk collection. Got the lever arm removed and ready for mailing. Do you need the ball receiver or ball linkage? I was on my way to the Post Office this afternoon but decided to ask you one more question. Other wise out it goes out tomorrow morning. Thanks. Tony |
Ball Socket Part #: 911-423-147-00-M100 But I'm not sure it will fit. Better to have the original part IMHO.
Throttle lever plus ball linkage.......
Duane, Both items on the way to LV. Tony |
ask tony if he has a 3.0 TB. it should help at WOT.
