Tim L's Avatar
Question Engine rebuild question?
My Bentley manual tells me I need to discard my engine oil cooler after a bearing failed. Is this necessary? How can metal get to the cooler since it must first pass through the oil filter.
Thanks,
Tim
Old 10-19-2001, 10:06 AM
Post
I can't answer your question with first-hand knowledge, but I have heard of several persons buying and installing used oil coolers coolers. They found out the hard way that the cooler came from a blown motor, and bits of metal had made their way into the cooler and into their motor. The result varied, but the result can be devistating.
It seems like cheap insurance to replace the oil cooler, or at the very least have it gone over with a fine tooth comb. You don't wantto invest $$$ in a rebuilt only to have relatively inexpensive part thwart your efforts.
Just my .02.
Paul
78SC Targa
Pelican Parts Members Gallery
Old 10-19-2001, 10:13 AM
Tim L's Avatar
Post
Where can I get one of these for under $1000?
Tim
Old 10-19-2001, 10:46 AM
Post
You were quoted $1000+ for an oil cooler? Please describe.
Oil coolers can be cleaned ultrasonically. Sill not a guarantee, but if done correctly, should be okay. I'd say this is a must before mounting any used cooler in an engine.
Sherwood Lee
http:members.rennlist.org/911pcars
Old 10-19-2001, 11:18 AM
Irrationally exuberant
ChrisBennet's Avatar
Post
These guys ultrasonically cleaned mine.
I think it was about $75 per cooler. Very nice to do business with. They deal mostly with small aircraft oil coolers.
Pacific Oil Cooler Service
El Monte, CA
1-800-866-7335
Note: If you get a used oil cooler be sure to have it checked for leaks. The engine cooler I sent to Pacific was found to leak, the one I have on my engine now seems to leak and I know of two others that leaked.
[This message has been edited by ChrisBennet (edited 10-19-2001).]
Old 10-19-2001, 11:48 AM
Tim L's Avatar
Post
pelican part #C-107-041-00 cost $1070.60
Tim
Old 10-19-2001, 11:52 AM
