The weak point of the drivetrain will for sure be the 915 internals. I would build that as strong as money can and not worry about G50 axles (unless they provide some other benefit?).
We built a 915/63 for a customer mating to a 3.6. Put in a Guard limited slip, Wevo bearing plate and a CMS side cover with Turbo bearing. He's used the car hard and it keeps going. The CMS side cover is beefy and not a factory look. I'd use a 915/73 side cover if that was important.
The G50 axles, which started in 86 on the 915/73, are Turbo size and incorporate the drive shaft/stub axle with the main. CV joints are sealed too. |
Just took off rear bumper and rocker covers in preparation to fit the new genuine porsche 930 flares. Complete bumper was 53 pounds, I did not weigh the rockers but they have to weigh at least 10 pounds also http://forums.pelicanparts.com/uploa...1483979214.JPG http://forums.pelicanparts.com/uploa...1483979214.JPG http://forums.pelicanparts.com/uploa...1483979214.JPG |
Looking good, Dave! Can't wait to see how she turns out.
Subscribed...
I sent you a message in regards to your rear deck lid and both bumpers bro, in your sales thread thanks Jr
Sent from my XT1650 using Tapatalk |
Been gone for a bit but back in action now. I forgot to snap some pictures yesterday as I was picking up parts all over town but here is something I picked up from Efren "blackbyrd" before I left. We were going to go 3.6 but Efren had these brand new Mahle 3.8 P&C so the new motor will now be 3.8 :)
http://forums.pelicanparts.com/uploa...1485263527.JPG http://forums.pelicanparts.com/uploa...1485263527.JPG http://forums.pelicanparts.com/uploa...1485263527.JPG |
Back from vacation and back to work, like to thank a couple local San Diego guys Brian Pauter at Pauter Machine for the awesome rods made in house, and Ira Ramin at Tarett Engineering for the killer rsr sways made in house in SD. Doing my part to make America Great Again, and support the local guys that create some of the best products on the globe.
http://forums.pelicanparts.com/uploa...1485403677.jpg http://forums.pelicanparts.com/uploa...1485403677.JPG http://forums.pelicanparts.com/uploa...1485403966.jpg http://forums.pelicanparts.com/uploa...1485403966.jpg http://forums.pelicanparts.com/uploa...1485403966.JPG http://forums.pelicanparts.com/uploa...1485403966.jpg |
Subscribed. Exciting project!
Where did you get the brakes?
Excellent!! Looking forward to watching this unfold! Love seeing all the goodies sorted out on the floor :)
More boxes today, 60 pounds worth of noise suppression and thermal insulation from Second Skin Audio and what ITG calls their "sausage" style air filters, I can't wait to see how these look on the motor.
http://forums.pelicanparts.com/uploa...1485497082.JPG http://forums.pelicanparts.com/uploa...1485497082.jpg http://forums.pelicanparts.com/uploa...1485497082.jpg |
Nice Porsche porn, subscribed!
Thanks, Eddy |
FYI IF you don't have a room booked you need to get that done. I just booked last week and there are not a lot of choices left. Most hotels are booked solid. Of course the $1,700.00 per night resorts still have plenty of space if your're into that sort of thing. |
Where did you get the center fill gas tank part? What is your intended procedure for that, new tank or utilize the existing? Also curious where you found the yellow lenses. Subscribed.
When I cut the hole for the center fill I will determine if I need to go with a new one or use the existing one. I got the center fill from a friend, he sourced it in Germany. |
Subscribed.
http://forums.pelicanparts.com/uploa...1486193412.JPG
http://forums.pelicanparts.com/uploa...1486193412.JPG http://forums.pelicanparts.com/uploa...1486193412.JPG http://forums.pelicanparts.com/uploa...1486193412.JPG Trans being rebuilt with new synchros, dog teeth, wevo bearing retainer plate, wevo side cover with larger differential carrier bearing, precision shift joint, g50 output flanges and g50 axles and lsd. |
| All times are GMT -8. The time now is 10:46 PM. |
