Help 964 G50 & 3.6 swap into SC question
I've been reading many of the threads on these swaps and have a question.
My car is a 1980 Sc and I have converted it to coil overs. I have a donor 1990 934 with the 3.6 and G50. My plan is to cut the torsion housing to make it fit but my question is the shifter. Can you use the 915 shifter and mod the shift rod to work with the G50? could you use a Carerra G50 shifter and rod with the 964 G50?
Any ideas and help are greatly appreciated.
Old 12-23-2016, 04:49 PM
SoyRacer's Avatar
You can use a G50 shifter assembly
But . . . .
You'll have to modify the tunnel hump for transmission clearance
and you'll have to make a junction to mate the shift rod to the selector shaft.
I've done a few and the selector shaft on the transmission is the determining factor (shift linkage securing bolt horizontal or vertical)
. . . . and obviously a G50 pedal box with clutch master cylinder, hard lines, slave cylinder, custom axles custom transmission mount . . . . but I'm sure that's all been covered in posts ....
Good luck !
1973 Porsche 911 RS
1981 Porsche 931 Euro-Intercooled-GT
1984 Porsche 911 Euro Carrera widebody
1987 Porsche 924s Rallye Spec
Instagram: @soyracer
Old 12-23-2016, 05:37 PM
Thanks for the reply, Is it possible to use the 964 pedal assembly or better to find a carerra unit?
Old 12-23-2016, 06:36 PM
SoyRacer's Avatar
964 is a completely different chassis. Pedal components cannot be retrofitted to G series cars.
Carrera G-50 pedal box only.
1973 Porsche 911 RS
Old 12-23-2016, 08:49 PM
safe's Avatar
A 3.2 G50 shifter housing is needed.
If you're crafty with power tools and welder you can add a clutch master cylinder to an early pedal box. Otherwise a G50 pedal box should be on the shopping list.
Old 12-24-2016, 05:42 AM
Thanks to all who replied, this helps greatly.
Old 12-24-2016, 06:23 AM
I had someone mention they were able to use the 915 shifter with a G50 swap? has anyone tried this?
Old 12-30-2016, 08:29 PM
No way.
The pivot for each transmission is 180deg apposed.
If you use (can) a 915 shifter 1st will be located where 2nd is, everything shall be reversed.
Old 12-30-2016, 10:03 PM
safe's Avatar
Originally Posted by robcf View Post
No way.
Well, 1st would wound up in forth or something like that. Everything would be reversed up will be down, left be right....
The 915 shifter also has spring loaded positions for reverse and fifth. The G50 shifter has nothing like that, everything is in the gearbox.
Old 12-31-2016, 02:23 AM
drola's Avatar
i have a 1976 912E with a 3.2 turbo putting over 700hp to the wheels and it has a 993 C2 6 speed. it had to have a late carrera g50 pedal assembly installed as well as the shifter assembly from the 993. i did not do the conversion so all i have to go by is what i see.
and from my own experience working on my 964 shifter and many 915 shifters, i don't see how a 915 could be made to replicate the g50 from the 964
i'm no expert though, just my 2 cents
IG @Drola964
1973 BMW 2002
1990 964 C2
2007 GT3
2014 Ram 2500 Cummins
Old 12-31-2016, 06:38 AM
