Always Be Fixing Cars
How many conductors in 3.2 throttle pos sensor
I removed the lower throttle position sensor on my 87 and think I heard some part of the plug go flying. The female plug (in my hand) has two conductors. The male has three. Did I wumpus one or is this how It left the factory?
'91 964 C4 - New Daily
'73 Alfa GTV - 90% done 50% to go
'65 912 - Welding in process
Old 01-17-2017, 05:00 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Ouch, yeah you lost the connector, easy fix, get a injector plug rebuild kit and replace.
'85 Carrera Targa
PCA/POC
Old 01-17-2017, 05:13 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
This looks perfectly fine. Each micro-switch has its own connector and is a 2-terminal device. That's why there isn't anything one of the slots.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 01-17-2017, 05:52 PM
Hold on which is it? Can someone kindly pull their lower tps and look inside the female plug for me?
Old 01-17-2017, 06:44 PM
ischmitz's Avatar
If you don't believe measure inside the 35-pin connector what the DME sees when you close a switch. It's pretty simple. Use an Ohm meter. One lead to a GND pin (pin5, 6, 16, 17) and the other lead to the respective switch. Idle is on pin 2 and WOT is on pin 3. Once a switch is closed you should a couple of Ohm.
Old 01-17-2017, 06:54 PM
DRACO A5OG's Avatar
Oops, my bad, I stand corrected, Just went to my car, there are only 2 female terminals in that 3 slot plug.
'85 Carrera Targa
PCA/POC
Old 01-17-2017, 08:10 PM
appreciate it guys
Old 01-18-2017, 05:26 AM
