Always Be Fixing Cars
How many conductors in 3.2 throttle pos sensor
I removed the lower throttle position sensor on my 87 and think I heard some part of the plug go flying. The female plug (in my hand) has two conductors. The male has three. Did I wumpus one or is this how It left the factory?
'91 964 C4 - New Daily '73 Alfa GTV - 90% done 50% to go '65 912 - Welding in process |
Member 911 Anonymous
Ouch, yeah you lost the connector, easy fix, get a injector plug rebuild kit and replace.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
This looks perfectly fine. Each micro-switch has its own connector and is a 2-terminal device. That's why there isn't anything one of the slots.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Hold on which is it? Can someone kindly pull their lower tps and look inside the female plug for me?
If you don't believe measure inside the 35-pin connector what the DME sees when you close a switch. It's pretty simple. Use an Ohm meter. One lead to a GND pin (pin5, 6, 16, 17) and the other lead to the respective switch. Idle is on pin 2 and WOT is on pin 3. Once a switch is closed you should a couple of Ohm.
Oops, my bad, I stand corrected, Just went to my car, there are only 2 female terminals in that 3 slot plug.
appreciate it guys
