Vintage Motorsport
The OP has the right idea. This car/airplane engine has been done more than once.
![]() ![]() A few years back I was staged in back of a jet dragster. Now that was an experience. Richard Newton |
Caveman Hammer Mechanic
Been wanting to do this for years in an aircraft, gas turbine running a generator, attached to a glider, altitude record for electric powered plane. All I need is a huge pile of someone else's money.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Formerly known as Syzygy
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
And people have put turbines in motorcycles even - Leno's got one.
https://www.youtube.com/watch?v=t0KjVz6uSS4
Juergen
'86 Carrera Cabriolet Grand Prix White '09 VW Beetle Convertible ‘24 Audi Q8 etron |
Racer
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
The owner said the mileage was about a gallon per block. Certainly not gonna win any accolades from Greenpeace...
Under the radar
Since we are talking aircraft motors. Has anyone ever seen this truck? 3 Pratt & Whitney J34-48 jet motors.
Shockwave.
RETIRED
They put a Spitfire motor in a Bentley.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Yep, V12 Merlin into a Bentley and a Rolls.
______________________________ Dave 1969 911T Coupe 1972 911E Targa |
RETIRED
They took the governor and turbos off. They handle like a 10 tonne truck but go like shyte in a straight...
It's a 914 ...
It might hurt the resale value of a 911, but heck, if it makes you happy, go for it! If you do it, please post a few pictures ...
Air-cooled GA engines are built to looser tolerances for better reliability at low RPMs. Spin them above 3k for any extended period of time and you will probably lose the reliability advantage.
The Piper Arrow I fly has a max continuous limit of 2700 RPM (@~200hp). Controlled by an adjustable pitch prop. And they only hold a max of 8qts of oil. But, I'd love to see you try and what solutions you come up with. I'm sure it could be done....somehow. The only reason the aviation engines cost more to rebuild is because they're...well, FAA regulated mechs $$ working on them. Everything's a lawsuit once you're airborne. If you did the work yourself you may not have that issue.
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs Last edited by flat6pilot; 12-28-2016 at 11:39 PM.. |
Continental in a vw:
https://www.youtube.com/watch?v=J4IzSXvUoyc
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Kessel run in 12 parsecs!
Why not just go down to a local airport, learn how to fly, get your private pilots licence, and save money on destroying a good Porsche and a Cessna or piper in the process.......
RETIRED
The W 12 was a very popular Pre WWI engine that was modified for many subsequent uses. https://en.wikipedia.org/wiki/W12_engine
Diss Member
HorstP pretty much covered most of it in his post but to add a few things...
To quote my ground school teacher in high school, "If we put an airplane engine in your cars all of you would seize them in a week with all your getting in and revving them and driving them before they warm up." (Yes. Ground school was a course in my high school!) An air cooled engine designed for operation only with a careful check listed startup, regular tear down based maintenance, fixed low RPM operation, and cooling from a completely consistent high speed air source coming from the direction of the crank flange instead of from above. Water cooled engines will let you have a bit more wiggle room but the fact is it is a lot easier to adapt an automotive engine into an aircraft then the other way around. - Oh and a turbine is no cake walk. Find Leno's video about what he had to go through designing his "Jet car". An engine that idles at 80% of full RPM is not easy to use in a wheel driven car.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Correct me if I am wrong, but was it mentioned why Aircraft engines are designed for lower rpm??
The speed at the tip on the propeller is the limiting factor. When the propeller tip goes over the speed of sound it loses lift and becomes way less efficient. Aircraft engines are designed for much lower speeds than and automotive engine.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
912 Geek
Here's a shot of the circa-1960 Porsche 678/4 aircraft engine that Dennis Frick (Europa Macchina) restored for me a few years ago. I found it in Trade-A-Plane. It was set up on a portable stand, and we ran it at the 2009 Parade concours. Twin ignition, dual fan belts, gear reduction unit (about 50%), dry-sump lubrication, etc.
![]() Frank |
My Turbo has an 930/67 aircraft engine (at least crankcase)
Roland 930 Turbo '81 Too many modifications to list |
| Tags |
| airplane , airplane engine , pfm 3200 |
