Alex599's Avatar
Help needed removing the shifter pivot cage
Howdy guys,
I can't seem to be able to remove this Allen bolt to free the pivot cage. Am I missing something? I tried heating it up and torquing pretty hard without success. Any ideas?
Thanks,
Alex
1984 Carrera 3.2 Cabriolet
Old 01-05-2017, 06:43 PM
Elombard's Avatar
Yeah I broke my tower trying to get it loose.
be careful.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 01-05-2017, 07:03 PM
I find it easier to loosen the lock nut with the tower still attached to the car, then the bolt just turns out freely.
Old 01-05-2017, 08:02 PM
repeated liquid wrench and tighten it then more lubricant and keep at it .....carefully.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 01-05-2017, 08:08 PM
Alex599's Avatar
Soaking overnight. Let's hope it loosened up.
Thanks all,
Alex
Old 01-05-2017, 10:40 PM
Put it back in the car so you can get some leverage on the large nut. Also worth noting that in my first go at this job I messed up the threaded pin and found out it's virtually impossible to find a replacement on its own. A pelican came to the rescue with a complete shifter assembly.
1982 911 Targa, 3.0L ROW with Webers
Old 01-05-2017, 10:48 PM
This!
It's a lock nut doing exactly it's job.
76 911S
Land Rover 110 Defender
Old 01-05-2017, 11:39 PM
Alex599's Avatar
I tried clamping the tower down after a night of soaking in penetrant. No luck. How much can I heat this part? Is it possible to overheat it with a blow torch?
Also, I don't have to unscrew the brass nut right? It only acts as a "depth locker" for the Allen bolt right? The way the threads go, I don't see the brass nut impede the release of the black Allen bolt. Having said that, I've been known to be wrong!
Thanks,
Alex
Old 01-06-2017, 05:09 PM
Thanks,
Alex
Wrong.
undo the "Brass" nut first. It's what's locking the screw in.
76 911S
Old 01-06-2017, 05:17 PM
The allen bolt is theaded into the housing. and the Nut is trying to pull the tread out of the housing and s such putting pressure on the allen bolt and 'Locking' it into position.
Undo the nut first while holding the allen bolt still with an allen key
76 911S
Old 01-06-2017, 05:20 PM
Alex599's Avatar
Ok, thanks. Having said that, I tried the nut, it doesn't budge. I'll try more penetrant. Thanks guys.
Old 01-06-2017, 05:46 PM
Yes it's a pain. there's no room to get a socket or ring spanner in there. just have to use a good open ender with brute force while holding the housing. I remember mine was tight.
76 911S
Old 01-06-2017, 05:52 PM
Before you waste anymore of your time, why not bolt the base back into the car and unbolt the lock nut with a socket. It will make your life easy. No chemicals, no flames and no frustration.
Old 01-06-2017, 05:54 PM
22mm 1/2inch drive fits perfectly.
Old 01-06-2017, 06:00 PM
Alex599's Avatar
I'm on it!
Old 01-06-2017, 06:18 PM
Alex599's Avatar
I assumed a socket wouldn't fit in there.
Alex's learnt lesson of the day: Never assume!
Thanks all!
Old 01-06-2017, 06:23 PM
did you get it?
76 911S
Old 01-06-2017, 06:36 PM
Glad it worked out!!
Old 01-06-2017, 06:38 PM
Alex599's Avatar
Originally Posted by psychoideas View Post
did you get it?
I did, thanks. I clamped the tower to my workbench and used a 22 mill socket and barker bar.
Old 01-06-2017, 11:22 PM
Awesome!
What are you doing? a refurb or wevo type replacement?
76 911S
Old 01-07-2017, 12:15 AM
