Update, received my package from Amazon, the single round USB device that was supposed to have a voltage meter inside of it didn't, so I returned it. Kept the 3-outlet panel. I think I'll replace the cigarette lighter with the USB charger, and ad in the voltage meter beside it (I have some momentary switch in that hole, not hooked up to anything at the moment as far as I can tell)
Will report back once installed. Should these devices be connected with new wiring straight back to the battery, and controlled with a relay triggered by the accessory line on the ignition. or a fused low current line to the accessory line from the ignition?
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end. http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html |
Eng-o-neer
The draw will be minimal. The existing wires will be fine.
It's worth noting that the voltage at the cigarette lighter might not be the voltage at the battery due to old/long wiring. Better than nothing, though, I suppose... |
Burnin' Rubber
I've got a great unit. I'll post a pic.
USB is 5.1vdc at about .7A You can find chargers that are a little high amps but pretty close to that.
72 2.7 Driven! |
Following this thread. I'd also like to add dual 2.1A USB charging ports somewhere inconspicuous. I had looked at the marine ad-ons suggested before but would like a more stealth install.
Since I've got a no-console '72, I've thought about adding a VDO gauge pod similar to the one shown here (this is a Pelican's ride, don't remember who's), cutting small slots for USB and mounting the guts of a car charger behind the panel. Could also drill and add a power antenna up/down switch for when I'm listening to Bluetooth being fed in thru the aux port in the back of my old Blaupunkt radio. Stealthy and more appropriate looking for a vintage 911 interior than those blue LED marine things. |
Eng-o-neer
In terms of simple USB charging in a car, I haven't found anything better than this:
https://www.amazon.com/gp/product/B01CL01NAC/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1 it is a very discreet charger for the cigarette lighter. Two ports, both of which are powerful enough to charge a tablet while in use, with no fanfare or egregious protrusions. For increased stealth, one could rub off the white text, or just wire in an auxiliary socket someplace completely out of site. |
Burnin' Rubber
Anyone find a good USB port set up?
![]() ![]() ![]() The dual USB charger is 2.1 amps, so it's a quick charge akin to using an iPad charger for your iPhone. I also fused the USB charger. And the voltmeter is wired direct to the battery. Looks period correct for my '84 ![]() Last edited by Koizumi; 01-23-2017 at 09:58 AM.. |
Very nice.
Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
DustoffDriver
Here is my USB socket attempt with my 1986 Targa, which turned out pretty well. The USB and 12v power socket I used are, I think, from the same manufacturer as the ones posted by BERGO on 1/18/17. The blue foam behind the face plate, and into which the back of the usb/12v sockets are placed, are water noodles from WalMart ($.96 for a 6 ft noodle). I had a machine shop create a faceplate for me according to a wooden template I gave them, then took all the measurement and drew up the draft you see here. Primed and painted and installed. No drilling required. Spliced into some power from the other wires behind the console. |
That looks exactly like what I want. Will you share precisely how you did that? I love that you used the blank next to the lighter
1988 911 Coupe Granite Green "Frogger" 1966 912R Coupe Stone Grey outlaw -"'Tilda" 1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter" 1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio) 1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001 |
Not necessarily blank, unless you don't have rear defrost.
Good luck, Dave
my less than 10€ setup
http://www.carrera-32.com |
Almost Banned Once
I'm Sad Man.
Sad Man doesn't like anything modern in his 1978 911SC. I get in and my phone gets chucked into the glove box. (I let all calls go to VM) No radio, just a cassette if I'm in the mood which is less and less these days. Just drive it and enjoy the serenity. There's nothing as good as that flat six wailing in the background. ![]()
- Peter |
Informative thread.
Banned but not out, yet..
I have something like this which is great because it works in your lighter port and gives you volts.
![]() Found here. Flight Gear Dual USB Charger - from Sporty's Pilot Shop
An air cooled refrigerator. ‘Mein Teil’ |
1979 911 SC
Was hoping for some newbie tech advice on this
Resurrecting an old thread here in the hopes someone in the know wouldn't mind sharing a little bit of Auto electrical 101 here. I would really like to add a USB port and a volt meter to place in the radio delete plate in my 79' SC. I really have zero experience with auto electrics and I'm wondering if it is as simple as splicing into the wires that provide power to the cigar lighter? Would anyone mind giving a reasonably detailed explanation of how this is done for a newbie please? I would like to retain the existing lighter port for the radar detector so tapping into but maintaining the original lighter would be ideal. Lot's of good looking solutions on this thread but I'm unclear on how to do it. Thanks!
Eng-o-neer
It is indeed. Use wires that are the same gauge or thicker, and just splice into the positive and negative wires on the cigar lighter. A voltmeter uses so little juice that the chance of blowing a fuse while you light up a fat cigar are near-zero, and if you use the same gauge or thicker wire, you don't need any additional fusing.
For USB, you can buy a USB charger that plugs into the cigar lighter socket for $15. You can also splice here if desired, but there is a chance of blowing a fuse while you're charging two iPads and lighting a fat cigar (otherwise, still a low chance of blowing a fuse). |
1979 911 SC
Thanks Tremelune! Are the wires accessible from beneath the dash or will I be going in through the frunk?
Eng-o-neer
Oh you know...find the cigar lighter and just start yankin' sh:t...
This post showed mounted a voltage gauge and USB ports in the ashtray. Slick setup and hidden when the ashtray is up. Im sure one of the amazon kits could fit as easy as what the person did.
Ashtray Modification (USB + volt meter install) Last edited by AlKidd; 03-04-2021 at 06:32 PM.. |
