RETIRED
PM'd you my email.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Banned but not out, yet..
Since fogs are useless I rewired them to go on using the switch alone and pointed the fogs up just enough to produce the desired effect. Not sexy but costs zero and works great. Bonus they turn on and off with the ignition if switch is pulled.
An air cooled refrigerator. ‘Mein Teil’ Last edited by RSBob; 01-26-2017 at 07:36 PM.. |
I did this, its super bright for just a single light.
78 911 st backdate 87 944 00 996 |
Thanks, Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
RETIRED
So Tim and I cut deal so I will have lit parking lights AND LEDs......
Burnin' Rubber
Adding day time running lights
Wired my yellow fog lights up for DRL service.
They can be turned on/off with the foglight switch. Yes, they run separately from the headlights or other lights. Most importantly, yes, they turn off when the ignition is off, so there's no way to accidentally leave them on. Last edited by Koizumi; 01-25-2017 at 05:32 PM.. |
El Duderino
This is how the Hella 450s look. The car is angled downward a bit because of the driveway.
The problem is that the factory fog light mount is directly behind the light. The Hella mount can be upright or pendant (hanging).. In the pendant position they can be angled more straightforward but they hang down lower than the factory lights. They were really close to the front spoiler lip so I was worried about the possibility of catching it on something. So I tried mounting it upright but there is only so much room because of the angle of the bumper. As you can see, it greatly limits how far forward they can project. But the point is really not seeing further -- the point is to be seen. I have also tried a couple of different LEDs but so far they are too long to fit.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. Last edited by tirwin; 01-26-2017 at 09:16 AM.. |
El Duderino
This is how it looks with the lights off.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
Maybe I'm confused , but why not just turn on the headlights during the day?
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
RETIRED
Where's the fun in that?
You might forget.
a.k.a. G-man
^^ I made a habit of turning my lights on before I go.
Like seatbelts, I never forget those either. Doesn't take long to get used to.
Сидеть, ложь, Переворачиваться |
Agreed. I turn on the lights in every vehicle I drive and I don't forget. Plus I also have daytime running lights on the rear (taillights) for extra safety.
1980 911 SC Targa 1969 912 project 1954 VW Beetle 3-fold ragtop 1979 VW Beetle convertible w/944 brakes |
RETIRED
While my headlights DO turn off when the ignition goes off the parking lights will stay on. My SC does not have a buzzer that alerts me to the headlights being left in the "on" position.
The module that will run the daytime LEDs is a cheap alternative. I would prefer this over leaving the headlight circuit active after shutting down the motor or any other accessory. I do have a dash actuated switch for interior lights but they have a visual telltale that is right under the key switch. I feel more comfortable with this set up.
Burnin' Rubber
My 1984 doesn't have headlight on buzzer either. It would be a nice addition.
I did remove the seatbelt buzzer though! That thing was annoying! |
Formerly known as Syzygy
Something that I do that's super easy is set my fog lights up to turn on when my car is running. I think you have fogs on your car...?
I just moved the fog light trigger power wire (the heavy grey one) at the back of head light switch to pin 75 of the switch. This terminal is always powered whenever the car is turned on. Then I pull on my fog light switch and forget about it. What will happen is that the fog switch will get power whenever the car is running and will trigger the fog light relay and turn on whatever lights you have on your fog light circuit. You will also be able to, perhaps if you're sneaking up your driveway late at night, turn off your 'daytime running lights' by just pushing in your fog light switch. But you could just leave your fogs on all the time and forget about them and they will automatically turn off when you turn off the car, and back on again when you turn the key and fire up the car.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Burnin' Rubber
This is exactly what I did! Very useful when set up this way! And it literally only takes a minute to do the mod. I leave my fogs on all the time. Hopefully one day I'll find a good bright LED H3 bulb instead of the incandescent H3 bulbs I've been using. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fog lights.
![]() ^^^^^ Here is my "easy" fix. Best, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Dial 911
Fuse # 11
Hi Gerry... Without going to our car to have a look, could you please tell me/us what item(s) uses fuse#11?...Thanks in advance!
m
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci |
![]() ^^^^^ Here you are. Best, Gerry
