Return Oil Line Install Issue
I'm having trouble getting the oil line to line up properly. It's hitting the other oil line and causing it to go in cooked.
I think the last time I had this connected I had the hard pipe not bolted to the tin. Can someone take a look and see if anything looks wrong. ![]() Sent from my iPhone using Tapatalk
Matt. 83 911SC 85.5 944 NA - Sold |
Picture of the other end........
Matt,
Post a picture of the other end of the oil line. Or better, a full shot of the whole oil line in question. Thanks. Tony |
Recently Disbanded
my S tube rubbed that crimped, fixed line after back dating my SC oil lines for an SSI install back in the day too. I used some bike inner tube to sleeve the S tube where it made contact. in this instance 3" should do.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft Last edited by juanbenae; 02-12-2017 at 06:13 PM.. |
Here's an overall photo. The two oil lines are touching and preventing the hardlines from connecting properly.
![]() Here you can see how it is not going in straight. I don't want to tighten it for fear of damaging the fitting. ![]() ...and yes my oil cooler is gold. I had it reconditioned by Pacific and they put some kind of coating on it. Sent from my iPhone using Tapatalk
Matt. 83 911SC 85.5 944 NA - Sold Last edited by arbita1; 02-13-2017 at 05:07 PM.. |
Oil return line........
Matt,
Loosen the 36-mm nut and slowly rotate clockwise or move metal tube section up. It is installed too low causing it to come in contact with the S-rubber hose. Tony |
