Paul S. (guest)
Guest
Posts: n/a
When replacing the rear window seal With defrost, 1980 911sc do you unplug the wires from inside the engine bay and then cut slots in the new seal to accommodate them with the window partially in place on the car OR remove the electrical harness from the car, rig and re-solder them out of the car and then fit the window into the car? Follow up, the harness splits into 2x2, two plug beneath the rear fuse box quite obviously. Two seem to ground behind the fuel filter and fuel accumulator? Thanks
This post was auto-generated based upon a question asked on our tech article page here: Porsche 911 Glass Removal | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
Old 02-24-2017, 01:01 PM
You know I have never done the rear window seal. I will create a post in the forums and see if another member can offer guidance!
- Casey
Fleabit peanut monkey
Bob Kontak's Avatar
- Casey
Hi Casey,
Is Paul able to respond to these posts or is he rendered passive if a guest?
1981 911SC Targa
Old 02-24-2017, 02:22 PM
Recreational User
porschenut's Avatar
I did this last year. Unplug the harness from the engine bay and feed the wires up through the hole in the rear shelf. Then remove the window from the car. Use a leather punch to create the holes in the new seal for the wiring to attach to the defroster connections on the window. Feed the wires through the new seal, put the seal on the window, put the aluminum trim in the seal as usual, and reinstall the window in the car.
It's not that difficult, but spend some time examining the old seal and see how the wires are routed and where the seal holes are before you begin on the new seal. When I did it, I made a diagram of the wires and where they attached to the defroster connections.
Old 02-25-2017, 07:53 AM
I need to do this on an early LWB, and unfortunately, do not have pics of how the wires for the defrost were run through the seal (do have the old seal though). I also have to see how the black "jumper wires" were attached between the leads on the bottom of the glass. At a loss here and if anybody has ANY pics of how this is routed, would be much appreciated. I don't know if this is shown on an electrical schematic somewhere.? Thx again
Old 02-26-2017, 07:13 AM
The rear window grid is a nice thought but that is why one buys the rear window with seal and aluminum in place with the wires hanging out of the corner.
Bruce
Old 02-26-2017, 09:04 AM
joefrantz's Avatar
I did it pretty much as Dave said. The hole punches are the only tricky part, but you might find that the wires have existing bends, from the prior install, that will point to where they want to pass through the channel divider in the seal.
Here is a diagram, and a few pictures.
Joe Frantz
73 911 T
Old 02-28-2017, 12:20 AM
Big Help there, Thank You. Assuming that is probably the same set up for Targa glass.?
Old 02-28-2017, 04:00 AM
Kool-aid-82's Avatar
Same for me the wires are the hard part.
Check out my install here
Getting my 81 911SC back on the road
Post 68.
Billy,
MoosgrunMetallic - 81 911 SC - (Carbon fiber Wrap)
Drank the Koolaid in 82
Old 02-28-2017, 05:44 PM
joefrantz's Avatar
Don't know where the contacts are located on the targa window, but the circuit would be the same.
Joe Frantz
73 911 T
Old 02-28-2017, 07:52 PM
