Cat bypass vs empty cat
what is the real difference between running a cat bypass and just clearing out the existing cat converter?
Any real horsepower loss or gain? I have a 3.0 in a 1972 and want to pull the headers and run the stock exhaust but don't want to lose a lot of horsepower. Thanks
Tom Feeney 1970 911 T 1973 911 T Looking for engine 6103643 |
No idea. I switched mine out to remove some heat on the engine (lived in "Houmidston" at the time) and a little weight. Sound was better. Very low. I'm guessing there would be no benefit without intake improvements. May even lose some low end.
1987 Guards Red Targa, cams, exhaust, MFI intake, lowered, 7 and 8's, 200,000 plus miles of smiles |
The motor has 964 cams and Webers on it. Currently has headers to a 2 in 2 out exhaust.
I went from a gutted cat pipe to a fab speed cat bypass. There was no noticeable performance change that I could distinguish. I was not expecting anything measurable anyway.
The sound did change, it became a little bit raspier with the new pipe. |
Diss Member
CAT vs no CAT generally doesn't give you a performance boost unless it was a really old style (unlikely) or unless the engine was retuned to deal with the change in the induction. Most improvement people report is actually the natural tendency to hear the louder noise and think they are making more power.
Unless you measure it it almost certainly your brain lying to you.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
So how do you gut a cat? (Pun intended)
911SC Tinkerer
Amstaff,
I can tell you about what's happened in reverse on a 3.0L. I went through a number of phases with the exhaust on my 911SC. I first replaced the cat with a Euro premuffler. Lost some torque in the low end but the engine was more free to rev to redline. Flat spot above 5500rpm shifted right to around 6000rpm. Next I went with an M&K GT3 style 1in2out muffler. More toque lost on the low end, louder on the upper RPM band, but no power band change other wise. Then I went with SSIs and a 2in2out GT3 Dansk muffler. Toque curve is flat from 2200rpm to redline when flooring it. In your case with a return to a stock SC heat exchanger set up I would expect an increase in low end torque with a flat spot above 5500rpm with a stock banana type muffler. Your going to feel a noticeable difference in the car. I would try what you want, but don't sell your old stuff until your happy with the new stuff. -Steve.
-'83 911SC Coupe SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc |
good article explaining exhaust pipe sizes related to power.
Header Basics - How Headers Contribute to Horsepower - Hot Rod Network |
Crotchety Old Bastard
The 3.0L SC engine responds best to 1.5" primary headers and a free flowing dual inlet muffler.
There is a bigger gain with the Carrera using a premuffler than with the SC.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
I have had both, but I didn't notice anything different. It would be a weight savings and perhaps a more laminar flow with the Fabspeed bypass.
Jase.
Jason Herriott 1986 951 (5 Speed) - Zermatt Silver Metallic / Black 1987 928 S4 (Auto) - Cassisrot Metallic / Burgundy 1988 911 (5 speed) - Silver/ Burgundy 1986 930 (4 Speed) - Oak Green Metallic / Cork (Wish list! )
Don't pull the headers on your 3.0L, that engine responds very well to 1.5" primary headers and a good flowing muffler. Why are you wanting to go back to the stock exchangers?
