Glad this thread is till alive. Not sure why I didn't post my car earlier. Still want to get some Ruf wheels, but overall I am happy with it. Sorry about the photo quality. Shot with my iPhonehttp://forums.pelicanparts.com/uploa...1306274702.jpg
http://forums.pelicanparts.com/uploa...1306274727.jpg |
Hey Jason,
Very clean install. Great looking car. What did you use for a ' SMILE'. The rubber between the front bumper and air dam? Thanks buddy, Scott |
Thanks for the kind worlds. When I bought the bumpers from Dave at TRE he mentioned a smile from a 964, so I bought one of those too.
Yeah Jason well deserved....... that aspect of the RUF bumper has always bothered me aesthetically. The slab like bumper up against the hood just looked too block like. You've created a very elegant solution...... looks factory to my eye.
Thanks for the quick reply, Scott |
Aluminum Splitter on Ruf CTR Front Bumper
Here are pics of my old aluminum splitter before I lost it during an agricultural excursion at Putnam Park's Turn 9.
Bob Farmer of Farmer Automotive (Greenfield, Indiana) fabbed it from raw aluminum and a jig saw back in 2003. He fastened the splitter to the fiberglass with bolts. It wasn't pretty, but it worked to keep the nose planted at high speed. Farmer made that splitter as a one-off fab job for my car's original owner, and Bob was not interested in making another one. With the splitter option gone, I was forced to go with Ruf's original front air dam Alois used on his original Yellow Bird. I'm using Ed's version (via Bill Verberg) of a Ruf front air dam using 4-in wide x 0.22-in thick conveyor belt material sandwiched between aluminum backing and the fiberglass. I'm going with Ed's suggested 3-inch reveal rather than Ruf's 2 inch reveal for maximum lift cancellation at high speed. The conveyor belt material apparently flexes for driveway curbing, but doesn't deflect at 130+ mph speeds. A big "thank you" to Ed for the front air dam fabrication instructions! I will post pics of my front air dam when the body shop finishes my car hopefully by mid-June. Quote:
http://forums.pelicanparts.com/uploa...1306409694.jpg http://forums.pelicanparts.com/uploa...1306409729.jpg http://forums.pelicanparts.com/uploa...1306409754.jpg |
Hey Manny (wolfrennen) - sorry I haven't sent the pics and destription yet, but it sounds like you've got it covered. Oddly enough, mine is at the body shop right now, getting a bumper/hood/fenders/paint after a collision with a deer.
I did almost exactly the same thing as Bill and Ed. 4" X .25" conveyor belt material from a farm supply store, 1" X .125" aluminum bar from Lowe's, stainless allen head hardware. Pics below. The aluminum was relatively easy to form to the bumper (bumper has to have the vertical lip at the back, some don't). I installed with about 2.5" exposed, leaving about 2" ground clearance with my lowered ride height. Wrapped the belt around the sides and radiussed the ends. I found this worked really well - gave me a little give for parking curbs and road debris, but didn't deform at speed. The difference in the car, with this and the 3.0 Carrera tail, was very noticeable - really settled it down, and it just got better with speed. I saw +/- 150 a few times and the car was rock solid. http://forums.pelicanparts.com/uploa...1306414764.jpg http://forums.pelicanparts.com/uploa...1306414782.jpg http://forums.pelicanparts.com/uploa...1306414796.jpg |
are you screwing right into the fiberglass, or drilling it first?
Oh no, definitely drilled first! I have a special set of bits that are made for Plexiglass, worked like a charm - super clean hole even for FG. The hardware is 1/4-20 stainless Allen/button head with a fender washer and self-lock nut on the inside.
Ok, I see, the valance turns up so you have a lip to mount on....
Correct - they don't all have the lip. For the bumpers from BW Motorsport, the ones with fog lamp holes do not have the lip, the ones with brake ducts do have the lip.
I'll have to check mine. I plan to do a track day at lime rock. highest speed I can manage there is about 115 so not sure if I even need the lip...
Do you have a tail? My setup improved the stability even at much lower speeds, like at 90 with a crosswind or headwind. Highly recommended.
I have an ma shaw ducktail. I just got a front oil cooler and the ruf replica valence in place of the stock valence with the lip spoiler
Wavey's Front Air Dam
Thanks for the follow up, Wavey. Feel free to send your pics to my personal email address. Good point about needing a lip for the aluminum backing to mount the air dam to!
Rennspeed Ruf CTR front bumper no lip?
I copied this pic from Rennspeed's site. Their Ruf CTR replica front bumper doesn't look like it has a vertical lip.
Forgot to post this one I did for a friend about 12yrs ago. Car is an 83 SC w/Bumpers from Brad. Color is fact Hellbronze met
http://forums.pelicanparts.com/uploa...1307109182.jpg |
My car is quite low and street-driven as well - the backing strip on the splitter hung up navigating ramps when the driveway was being re-concreted, so isn't presently fitted - but I really didn't notice any front-end lightness down the back straight at Pacific Raceways last week... |
So do you believe that the aftermarket RUF front and rear bumpers improve the areodynamic performance of an SC/Carrera with standard rear flares? |
In fact, what really bothers me is that if you look at pictures of the real Ruf, their front caps don't seem to have the flat surface on top that all the after market caps seem to - rather, the top surface of the Ruf cap seems to be shaped to mimic the line of the original factory impact bumper - which is curved there. It bothered me so much, I bought a used Ruf under-bumper valance, and am collecting parts & considering re-fitting the front bumper... |
Thanks, spuggy. I guess my bodyshop manager will need to install the L-shape brackets. as a work-around for the Rennspeed cap.
| All times are GMT -8. The time now is 12:32 PM. |
