-   -   Ultimate RUF Conversion Thread (http://forums.pelicanparts.com/porsche-911-technical-forum/94997-ultimate-ruf-conversion-thread.html)
MotoSook 02-13-2003 09:01 PM
dwight, did the vent/grill come with your valance? Else, where did you get it?
speeder 02-13-2003 09:35 PM
Looks like the old "cut an engine grille" trick to me, and a nice solution I might add. :cool:
dwightp 02-14-2003 12:36 AM
Yes, the vent/grill did come with the valance. It's actually a necessity as the valance has tabs that insert into it. It also has the mounts for the driving/fog lights. I also received a blanking plate for it (which I did not use) for use w/o an oil cooler.
turbo6bar 02-14-2003 11:30 AM
Bringing this to the top. Souk's web page has an update as of this morning. Need to do some research about MA Shaw's products.
Jurgen
pbs911 02-14-2003 11:47 AM
What do you want to know? I installed them on my 78.
exactly.
turbo6bar 02-14-2003 12:17 PM
From what I've read on Pelicanparts and Rennlist, the MA Shaw goods are the best. They fit very well and the finish is superb. From what I've read of the Rennspeed products, they also fit well and the finish is good. However, I remember reading about mikez's new bumper possibly needing some work, and that part was from Peter @ Rennspeed. I need to double-check on that.
Basically, my perception is the MA Shaw products almost always fit very well, and the Rennspeed parts are a good fit, but not guaranteed. Am I wrong in this perception? I do realize we are talking about fiberglass parts, and it's unreasonable to expect perfection. However, if one vendor's part is better, I'm going let that influence my final decision.
Regards,
Jurgen
pbs911 02-14-2003 12:26 PM
My MA Shaw pices were marked with dimples at the factory mounting points. All that was required was to determine the type of fitting and drill the size hole I wanted to use. Truely bolt on w/o mods to the body. The pieces fit the body curves perfectly.
I also have the MA Shaw fiberglass hood. It took a total of 10 mintes to install and fit like the OEM metal hood.
None of my MA Shaw pieces required ANY adiditonal work prior to paint. My car is black and the pieces lok like painted metal, not painted fiberglass.
Another thing to note on the MA Shaw pieces is the edge work. The edges are curved to provide added strength.
turbo6bar 02-14-2003 12:29 PM
Here's a link about mikez's front bumper install. Sounds like he had to do some trimming and the fenders didn't quite line up just right. Can you comment on the work you had to perform, Mike?
SC/RS front bumper install
Paul, sounds like you really like the MA Shaw parts.
I noticed one thread where Olsen really praised the fit of Rennspeed's front bumpers.
I'm just rehasing what I've read in the archives. I know products from either vendor would be pretty good.
Jurgen
rdane 02-14-2003 03:42 PM
I have talked wih 5 shops both locally and out of town about the YB set up front and back. Every shop recommends the Shaw pieces for quality and fit...both of which save us money in the long run. I mailed Shaw a check this morning for my set. Both pieces will be here next week. I have a Ruf lip and a old grill to cut up to cover the oil cooler hole until it is in. I am also leaving off my fog lights and ducting the new 930 brakes. I'll post before and after pictures if any one is interested when Mark @ Eurotech gets done with the painting.
Bill Verburg 02-14-2003 04:03 PM
You will need a second grill for the fog openings. Though I s'pose you could leave them open
http://www.owners-gallery.com/upload...r_small100.jpg
rdane 02-14-2003 04:38 PM
The plan at the moment is to vent the brakes to the fog light holes....if that won't work and come out clean, I'll put the fogs in them.
MotoSook 02-14-2003 05:03 PM
GROUP BUY
It has been a busy week, and it is not yet finalized! I will receive final information early next week. So those of you who are in the group (17-18 now I think) need to decide by the middle of next week. I have updated the Bat Cave with the latest infomation, so check it out.
On thing that I have learned this past couple of weeks is that the companies that are still in business making these parts are making good parts. There is little variation in the quality from what I can judge after my my conversation with the producers/venders and from the feedback of Pelicanites that have purchased parts.
If you think you will get a part and bolt it on in a few hours, think again. Read the threads of others who have installed the parts. I went after parts the were reported to have good quality. I also wanted parts that will only require fitting and drilling. Prep and paint is a given. I will do my own prep work and may have someone shoot it for me. But then again, it'll be a good time to buy a paint gun and put my monster (to me) compressor to good use. And it'll be a good primer for my big paint job (the whole car) this summer.
I expect to do work on my parts, because no matter whose part I buy, it'll never be good enough. I'll post a thread or webpage when I get my parts to document the installation process.
I will post another page to give a more candid opinion of the parts (sight unseen :) ). I tried to limit (tough for me to do) judgement on the infomational page, but on the "decisions" page I will share my honest opinion (much easier to do) so those of you on the fence might tip and fall on my side ;)
Thanks all for your interest in the group buy. Once this is over, we'll get back to the true spirit of this thread...pictures of Yellow Birds :D
turbo6bar 02-15-2003 11:05 AM
Souk, from what I've read about the MA Shaw parts, many guys are lucky enough to simply drill and bolt on the parts. I don't mind the paintwork and prepwork, but I'd be bummed if I had to pop open the can of resin and do some patchwork. I don't have much experience with fiberglass work, but if it is anything like body work, those hours add up REAL fast. I'm not accusing the Rennspeed parts of being subpar. I am still undecided, but I definitely want to take advantage of this group buy.
What about the other 15+ guys who are interested in the group buy? Any opinions whatsoever???
Jurgen
MotoSook 02-15-2003 11:17 AM
Jurgen and others,
I am not endorsing one vendor over the other, but I will give my analysis of the variuos vendors from my conversation with them. Also, there are tidbits that I did not reveal on the info page for fear of lashback. When the final info is in I will be sending out an e-mail.
One thing that I want to say is that the group buy is to benefit us in the group and the producers/venders. Unless we have a good size group for each vendor it may not be so good for us or the vendors.
As it is, there are over 15 guys who expressed interest and who are likely to buy, so even if we split the group, it will be good still.
The prices are great from all vendors, and a single buyer will not likely to get those prices. So we have done good already. I just don't want to affect the vendor's future business, nor the ability of other group buys. If this goes sour, other equipment vendors will not want to deal with us (Pelicanites). Although there is a slim chance of that, but my name and reputation is attached to this deal, and I sure a hell would like to maintain some respectability.
I'll report as soon as I have more information.
Thanks all for your interest.
turbo6bar 02-15-2003 11:26 AM
Agreed, Souk. No hard feelings whatsoever. I want to make the best decision to fit my needs and wants, but at the same time respect the desires and wishes of the group as a whole.
I have never installed fiberglass parts from any of the Porsche retailers, so my sole influence is the advice and opinion of those who've been there already.
Lastly, I have organized half a dozen group buys in the past with a net dollar value well into 5 figures, so I know what you're going through. Thanks a lot for your hard work.
Jurgen
pwm74 02-16-2003 09:51 AM
1 Attachment(s)
Grandma Ruf
keeping this thread alive
pwm74 02-17-2003 11:30 AM
BLACK
more picshttp://forums.pelicanparts.com/uploads/ruf black 2.jpg http://forums.pelicanparts.com/uploads/ruf black 3.jpg
pwm74 02-17-2003 11:31 AM
OOOH LALA
http://forums.pelicanparts.com/uploa...widebody 1.jpg http://forums.pelicanparts.com/uploa...widebody 2.jpg
Slider79SC 02-17-2003 12:48 PM
I know its the newer version, but I just couldn't help it.
http://forums.pelicanparts.com/uploa... DSC00320a.jpg http://forums.pelicanparts.com/uploads/DSC00309ab.jpg
Eric Mckenna 02-18-2003 03:51 PM
http://fr.mobile.de/cgi-bin/search.pl?CountOff=8&DataNr=0&DisplayDetail=111111 11114384757&DoSearch=1&FormCategory=14&FormColor=% 2e%2e%2ebeliebig&FormDate=0&FormEZ=%2d&FormKilomet er=%2d&FormLand=%2e&FormMake=0&FormModel=ruf&FormP lace=%2d&FormPower=%2d&FormPrice=%2d&FormSort=0&Pa ge=0&SearchCat=bereich%3dpkw%26sprache%3d4&bereich =pkw&sprache=4&x=53&y=4
Eric MCkenna
78SC
maxnine11 02-18-2003 03:58 PM
cool car in your link Eric... you seem to have a thing for black wheels!!!.....possibly a traumatic experience with brake dust on silver/chrome wheels in your past?? LOL , max
maxnine11 02-18-2003 04:50 PM
http://forums.pelicanparts.com/uploads/redrufblkw.jpg
Eric Mckenna 02-18-2003 05:00 PM
HAHAHAHA! yes Max I do have a soft spot in my heart for the blacked out wheels.. I love the look!
I also have a thing for these motors! :)http://forums.pelicanparts.com/uploads/trappes04.jpg http://forums.pelicanparts.com/uploads/trappes06.jpg
Eric Mckenna
78SCSmileWavy
ipapilot 02-18-2003 07:20 PM
I know Souk has been working on the group buy thing, but does anyone know if any of the potential vendors offer the rear bumper with the additional horizontal louvers like in Erics' picture?
JonT 02-18-2003 07:27 PM
Has anyone got into a front end collision with one of these new f/g bumpers? Are there safety issues to consider here?
turbo6bar 02-18-2003 08:12 PM
The converse to that question...does the stock bumper provide a reasonable measure of safety? I view most bumpers as simple 5mph protection, but I'm not sure if that applies to the Porsche bumpers. I bet a foam-filled fiberglass shell would provide pretty good impact protection, but that's just my opinion.
Jurgen
MotoSook 02-18-2003 08:53 PM
Well, if you are ever in an accident, that involves speeds greater than 5MPH, chances are, your bumper (stock or fg), fenders and hood all have a chance of getting damaged. Same goes for the rear parts.
If you want the air shock protection of the stock bumper, you can get one of our potential suppliers to fab you a setup for the rear using the pneumatic shocks from the front of your car. If you hit some with your front, well, then you are at fault...so it will seem to most officers that shows up at the scene.
Fact is, if you want protection you can build one into the conversion. You don't need an engineering degree to build it, just some determination. But if you need an engineer, my rate is $125/hr plus travel and lodging. :)
As for the slots in the rear, I'll ask.
pwm74 02-19-2003 08:56 AM
lets see how many carrera bodied RUF cars pics we can post
Slider79SC 02-19-2003 01:02 PM
souk,
The yellow Ruf that you posted pics of is for sale...
http://www.racinggallego.com/RUF.html
:D
MotoSook 02-19-2003 02:53 PM
Err, Slider, if I wasn't commited to buying the conversion parts, I would go and get that yellow car.... :) Maybe the folks in the group buy will all pitch in, and we can do a time share on the real RUF Yellowbird. How about it guys?
Anyways, I have new information to add to the info page, so check tonight. It maybe midnight (CST) before I get the update up. I think we are really for a vote guys so please get your wallets out. And those concerned with safety, I have good news too, kinda.
Thanks all for your interests. There were some late ones, but I think we may have 20 (!) now. Wahooo....the CTRWDP lives! :)
MotoSook 02-19-2003 07:40 PM
Ok guys. The last of the prices is in. Please check the Bat Cave. I'll give you tonight to think about it, then I will send out a speadsheet in the morning for us to vote on. The numbers are important as some of the prices require a minimum commitment.
I think all the options are great. There are enough of us to make at least two groups, so our preferences can be satisfied. Thank you all for your interest. It's been a busy couple of weeks for me, and I apologize if this has moved too slowly for some of you.
And! It's not to late for others to join the group and take advantage of the savings. E-mail me, soukus@comcast.net
Schuey 02-20-2003 09:02 AM
went to the batcave, would like some pictures on the BW Motorsports ones, so if ANYONE could post 'em it would be great...
MotoSook 02-20-2003 09:15 AM
Bill V has BW Motorsports' Yellowbird parts. I know it will be a pain (10 pages!), but look this thread over again, you will find pictures of his car. If you are looking for more detailed pictures, I think you (we are out of luck).
turbo6bar 02-20-2003 09:23 AM
I'd like to hear opinions from the other 20 or so potential buyers.
I'm not sure which product to choose. None stands out as the best, and they all sound attractive.
Jurgen
MotoSook 02-20-2003 03:43 PM
Sorry I did not send out an e-mail today, but I had an interview come up short notice.
Anyways, here are some pictures pirated from one of the other threads today, in case you didn't notice.
There is a vender in the US with turbo CTR bumpers.
http://forums.pelicanparts.com/uploads/930bbs.JPG http://forums.pelicanparts.com/uploads/930bbs2.JPG
Droool.
Eric Mckenna 02-20-2003 04:23 PM
wHERE IS THE LINK T THE BAT CAVE AGAIN?
ipapilot 02-21-2003 11:56 AM
Soooooo, what seems to be the general concensus so far? I kinda like the idea of having a little impact protection. Post your thoughts people!!!
Eric you have a PM.
Brian
bento 02-21-2003 02:47 PM
a quick question:
after looking over the thread it seems that some of the cars (the lime green one is the first to come to mind) have brake duct openenings that are smaller than the fog light opening. one of the cars has two rounds openening which i think deviates too far from the look, but that lime one has smaller square openings. is that a custom fitment on the standard YB bumper?
david
(I want the bumpers too, but i'll have to wait till summertime)
Schuey 02-21-2003 05:55 PM
I'm leaning toward MA SHAW or BW Motorsports b/c of "perfect fit" either would be nice...it seems the BWM may be a "safer" choice b/c of the bumper shocks...but right now I'm game for either of the ones above...I need to see a picture of the BWM's b/f I decide though...could anyone post a picture of these?
MotoSook 02-21-2003 05:59 PM
I wish I could get some BW pictures. I think Bill V is the guy for this, but he installed his so long ago that he may not have any.
Bill, if you have any more pictures, please post them.
