Journalist
AdamKaz's Avatar
Passenger Window Switch Mystery
Reassembling my car after paint and I've stumbled upon a glitch I can't figure out.
I have both window switches on the driver's side working, but I cannot get any switch to function on the passenger door.
I've tried multiple switches, both on the passenger side and the drivers side just to make sure. And of course, if I have no switch installed on the passenger side I get no function from the driver's side passenger switch.
So if the installed passenger side switch is working well enough to let the driver's door passenger switch control it (ie, getting current and hooked up correctly), why isn't the switch on the passenger side working?
What am I missing?
There isn't some child safety switch I'm not aware of is there?
"The Rain" 1988 911 Carrera Coupe
"The Dog" 1970 BMW 2002
"The Saint" 2012 BMW G650 GS Sertao
Old 05-07-2017, 12:32 AM
Check the connections on passenger side switch sounds like a wire isn't hooked up to the correct terminal.
Old 05-07-2017, 04:54 AM
May not be an electrical problem. Window mechanism may just be binding up... Read this: Power Window woes
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 05-07-2017, 05:21 AM
wayne robson's Avatar
window switches
Just in case these photos help, i removed door panel
about year ago to adjust window guide,so took a few photos
of window switch on drivers side only,these are how drivers side is wired
both are correct and work as they should, .
Old 05-07-2017, 06:05 AM
Vintage Owner
Jack Stands's Avatar
Window wiring diagram
This might help.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 05-07-2017, 06:37 AM
I hooked a small motorcycle battery up to the two blue wires off the switch to check my motors.
Old 05-07-2017, 11:56 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Window switches.
For our '86.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-07-2017, 12:30 PM
Journalist
AdamKaz's Avatar
Can't be this or the motor as the driver's door passenger switch (D/P) moves the window no problem.
And I've followed all the wiring diagrams/pics I can find here.
So I guess my question is this: Can the passenger door switch (P/P) possibly be wired incorrectly if the D/P switch still functions?
When I read the wiring diagrams, what I see is the D/P running THROUGH the P/P.And when I remove the P/P switch altogether, the D/P switch no longer functions.
Old 05-08-2017, 09:02 PM
Change switches to see if the problem follows the switch...
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 05-09-2017, 04:43 AM
Journalist
AdamKaz's Avatar
I've tried 2 different switches there, and I've verified that at least one of them works.
It's not the switch.
See, I told you it was mystery!
Old 05-10-2017, 01:10 PM
Looking at the Bentley wiring diagram, it looks to me like the passenger switch has its own ground wire. If that isn't a good ground wire, then that switch won't work locally. When operating that window using the switch on the driver's side the circuit uses a different ground wire. Therefore, I would check that the passenger door switch wire is solidly grounded by pulling the switch out of the door, and with an ohm meter, see zero resistance from the brown wire on pin 4 to a good grounding point.
Old 05-10-2017, 05:19 PM
Journalist
AdamKaz's Avatar
That sounds like a promising answer, and would make sense to me. I'll check it out!
Thanks!
Old 05-11-2017, 01:16 PM
Journalist
AdamKaz's Avatar
SUCCESS!!!
Yes, the passenger door ground was not longer "functioning". I'd never used my multimeter that way, so thank you that was super helpful and and a learning experience.
Rather than fish our the existing ground, I just ran a new one to a pre-existing bolt in the door and it's working great.
Thanks again SpyderMike!
Old 05-18-2017, 06:57 PM
Glad you fixed it!
Old 05-18-2017, 07:05 PM
