Radio block off plate doesn't fit
I just removed my radio and tried to fit the Porsche OEM block off plate. Well it doesn't fit at all. There are two tabs that are supposed to grip inside the hole and they don't. The only way I can see this working is by gluing the plate in. Has any one out there successfully mounted the plate?
thanks!
1988 Carrera coupe 1966 250 Ducati 2015 VW Golf TDI gone because Dieselgate! 2021 VW Golf TSI 2014 Ninja 300 |
The grips don't fit..or they don't hold it up tight? I bought the oem plate from PP and it holds just right. It will move around a little if you press on it...78SC
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Snitz,
on my '83SC, I trimmed (combination of cutting and fine-sanding) the plate to fit snugly in the opening, and used heat gun to soften and bend the tabs to better grip the backside of the opening. Fits OK after some fiddling. PD |
/ˈpɔrʃə/ PORSH-ə Fan
It's ridiculously overpriced for what it is and I've never seen one fit well without mods. It doesn't look that great even when it's all lined up.
1984 ROW Carrera Sunroof Coupe Schieferblau 1982 US SC Targa Moosgrun 1977 US 911S Sunroof Coupe - SOLD |
