/ˈpɔrʃə/ PORSH-ə Fan
Molykote Substitute and Temp Sensor Tool
Changing out the Temp Sensor on an '84 Carrera. Bentley manual calls for Molykote on the threads. Is Permatex Aluminum Anti-Seize an acceptable substitute?
Also, this special Porsche tool is listed as necessary to install. I was able to remove the sensor by cutting the wire and then using a closed end 13mm wrench. The replacement sensory looks to be 14mm, but I obviously can't cut the new wire. Open ended wrench is too big. Do most people simply cut a slit in a cheap closed end wrench to tighten?
1984 ROW Carrera Sunroof Coupe Schieferblau 1982 US SC Targa Moosgrun 1977 US 911S Sunroof Coupe - SOLD |
I used a pair of needle nosed pliers- not elegant, but sensor's still doing its job 20 years out
Or, get a grinder and slit a socket yourself (that's what I did).
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
I don't think the Permatex Aluminum Anti-Seize would be a good substitute since the Molykote HTP paste is zinc based.
Molykote HTP MSDS, see page 7 The Loctite Zinc Anti-Seize would be a better substitute. Zinc Anti-Seize |
There has got to be something acceptable that doesn't cost $50/can for one time use.
Milk of Magnesia
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Lol
After spending an hour grinding a deep socket perfectly it still didn't work because of the stiff insulation near the sensor. Basically wasn't deep enough. Cut a slit in a cheap closed end of the appropriate wrench like you mentioned. Easy peasy.
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250 |
Complete
The Bosch replacement sensor had Molykote already on it inside the plastic cap covering the threads. Problem solved.
And sometimes Harbor Freight is the answer. This modified wrench made quick work of it.
Glad to hear everything worked out.
Harold |
