69' Brembo caliper upgrade with SC rotors
I recently purchased a set of Brembos off an 80's Alfa GTV6. They have the 3" spacing to fit the strut assembly of my 69'. Paired to it are some SC rotors and I could not be happier with the bolt in fit. The stock M caliper only has one slot for the banjo bolt to fit in, whereas this has 2 bleeder valve. Does anyone know which valve I should remove to fit the banjo bolt? The top vs the middle, or if it even matters?
1969 Porsche 912
Looking for Engine #4096213
Old 04-19-2017, 09:04 AM
Put your admission port on the lower location. Air needs to be bled off the top of the caliper
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 04-19-2017, 10:52 AM
Makes sense. Thank you.
1969 Porsche 912
Old 04-19-2017, 02:08 PM
