No LSD on turbo?
997 Turbo went "bang" and then no more response to throttle on highway. A tow to a dealer resulted in a $33K quote to replace the Tipt gearbox because it no longer engages gears. On the rack, I noticed the left drive shaft came away from the gearbox flange and took out the last M10 CV bolt. Cleaned everything, re-tapped the flange, new M10 bolts, Schnor washers (not on car before), Loctite and safety wires on both sides. Those suckers are never backing out again.
So, how come the detached shaft on one side disabled the gearbox? Would the LSD allow the car to move anyway?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 05-23-2017, 06:04 AM
T77911S's Avatar
my 88 BMW has an LSD. 25% I think.
I can still spin the inside tire.
may be wrong but is you have no resistance on one side and full grip on the other an LSD wont matter, only a full lock up.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-23-2017, 06:28 AM
gearhead
The modern lsds are zero preload and act like an open diff when "tested". I've never heard of a tip with an lsd.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 05-23-2017, 06:45 AM
