Brake bleader fitting size for '80 911sc
Speedbleeder fittings for brake calipers---makes it one-person project to bleed brakes. Need help with exactly what size fitting to get for '80 911sc? TY!
Speed Bleeder Sizes
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
but as a FYI, I wouldn't recommend them, they are prone to failure down the road
Thanks Bill. Too bad down-the-road failure. Any similar system that holds up?
Most cast iron calipers use the M7 x 1.0 thread size.
Most aluminum calipers use the M10 x 1.0 thread size common to the brake line hydraulic fittings.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
