Halm's Avatar
Replacement coil?
I have been gone from this forum for a couple of years as I experimented in the water-cooled world. I am back now and looking to pick up a spare coil.
I did a search and looked through the parts catalog to see if anything new was available. I didn’t find much so I will ask: What is up in the world of coils? Is there a preferred route to go? Is the silver coil still a POS?
Thanks for any and all help.
'17 Cayenne
Old 08-08-2017, 11:05 AM
Yes. The MSD blaster epoxy filled coil works with the stock bosch ignition boxes. Just peel the sticker off.
206 637 4071
Old 08-08-2017, 11:22 AM
sent you a PM...............check it out.
Old 08-08-2017, 11:30 AM
Halm's Avatar
Excellent. Thanks, John!
'17 Cayenne
Old 08-08-2017, 11:59 AM
Is the MSD coil ok to use if Pertronix is installed?
Old 08-08-2017, 02:27 PM
wrxnofx's Avatar
To clarify further, do you mean the MSD Blaster 8222 coil?
Also, will that work with the stock Motronic ignition in the 3.2 engines, too?
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 08-08-2017, 02:47 PM
Do not buy a silver one from Brazil
Willie
1983 911 SC 3.0
Old 08-08-2017, 04:04 PM
KNS KNS is offline
Is the MSD Blaster coil OK for the SC and 3.2 both?
Kurt
Old 08-08-2017, 06:09 PM
There are alternative high voltage coils of new design / manufacture specifically designed for the Porsche CDI ignition.
Old 08-08-2017, 07:53 PM
Parts?lassi? makes a CDI coil that is very close to the original Bosch coil.
Old 08-08-2017, 08:05 PM
Replacement coil?
Finding a replacement for a 3.2 Carrera is a challenge. The SC with CDI coils is different.
I finally found a used original black coil. It is sad that a 30 plus year old coil is the best option for a 3.2 Carrera.
Old 08-08-2017, 08:18 PM
8222, yes. Wouldn't use it on a 3.2.
206 637 4071
Old 08-08-2017, 08:19 PM
