Oil cooler bypass with new install in different location
Can anyone here tell me if I can install a new oil cooler on 75' 911S also bypass the old one and leave it attached instead of remove it for future maintenance ?
E-85 sippin drunk
Do not have a clue what you are trying to ask. Are you wanting to install a new engine mounted oil cooler, but leave the old still attached? if so, then no, that can not be done.
Are you asking if you can add a new fender or front mounted oil cooler, but bypass the engine mounted oil cooler, and still leave it attached? If so, then no again. If you are wanting to add an aftermarket oil cooler in the front of the car, fender mount etc, and not wanting to have the engine mounted oil cooler, why not take the engine mounted oil cooler off, and instead of trying to bypass it, install a second oil filter utilizing the oil filter console from a 993 3.6L? That way, you will add a second oil filter, and keep things simple... Also if you go that route of adding the 993 oil filter console, remember you have a raised portion on your air shroud that directs air from the fan towards your engine mounted oil cooler. You will have to modify that someway. ( I just cut mine off, and using a piece of carbon fiber, just filled in the cut out raised portion.
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
E-85 sippin drunk
I will take a few pics of my setup in an hour or so, and post them when I get back from lunch
Registered Minimalist
Yes. You have several options.
You will continue to use the engine mounted cooler in either case. 1. install factory lines from an SC with a "trombone" style front fender cooler. 2. install aftermarket kit like I have from one of the vendors such as Elephant Racing. 3. install a mocal kit that is not factory looking but generally cheaper. 4. home made oil kits using various off the shelf components and AN connections/adapters. Generally you need: Oil thermostat Feed line return line Front mounted cooler (carrera style or trombone) electric fan for bonus Flex lines to attach from hard lines to cooler. crossover line (unless you already have it. Moves the oil line from the back of the engine to the front. 2 new lines from t stat to x over line and t stat to original cooler that's on the back of the engine. In my build thread Here is a google doc of my cost break out sheet and part numbers.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads Last edited by 75 911s; 05-31-2017 at 10:17 AM.. |
E-85 sippin drunk
And here is what I did. I sourced all of my parts from Summitt Racing (which a distribution store is 45 miles from me), and it came to just under $900 for everything I needed.
I do not run an engine mounted oil cooler, and run the 993 oil filter instead. My Link ECU controls the fans. The fans barely come on (only in prolonged stop and go traffic), and in the dead of summer here in the Atlanta area, my oil temps hardly ever get past 215 deg. Here are a few pictures. Hope this helps. [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]()
Thanks Brad, from looking at your set up. is your two coolers run the oil cooling without using the factory oil cooler unit, and your 2 unit fans are placed in blow upward?
As I mentioned on the beginning, I like to use one oil cooler (New Installed) and not using the factory unit attached to the engine but not taking it out from the car |
E-85 sippin drunk
![]() [IMG] ![]()
b) do you already have oil lines running the passenger side to the front right wheel well? regarding b) its as "75 911s" said regarding my experience -and in case you do not care too much about period-correctness- then don't go for the trombone (cooling is poor compared to technical effort put in installing it) but go for later versions, at least the 20-rod cooler. much lighter is the Carrera 3.2 one. the fan is not obligatory (unless you ride in a generally hot area). regarding the engine-mounted pre-cooler, I'd not envisage deleting it. unless you change to some super crazy racing setup. stay stock in this detail. to suport a future oilcooler you'll need this suport: 91150149001 brackets at top: 91150349201 + 93020792100 (welded in at rear of headlight bulge)
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit Last edited by Flojo; 06-01-2017 at 06:06 AM.. |
E-85 sippin drunk
As far as brackets go, if you want to pay the extreme prices for a factory Porsche part, then yes, get the part numbers mentioned above. If you are going aftermarket, dont bother with the factory brackets. Instead, fabricate your own. I was forced to make my own brackets, as I put the largest cooler I could fit in there.
It was just a sort of U-turn device. Don't know if it was factory or after market, but I have seen one. Perhaps on old SmartRacing part.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
E-85 sippin drunk
I am running a 3.8l engine (not having a engine mounted fan) with 2 coolers in the front, I would toast the engine without a fan in stop and go. |
E-85 sippin drunk
I agree on that. Since I have a fan on each of my coolers, they catch the rise in temp quickly, and they are not on for very long.
Turbobrat930, he has a 77 S and not a3.6l ;-)
HorstP, only if he does not delete the engine-mounted cooler ;-)
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
a lot of their parts when Smart Racing quit offering all their goodies. Might check with Jerry.
